![]() | Home > Maintenance & Mods (L405) > Restrictice Performance |
ilard Member Since: 21 Oct 2012 Location: London Posts: 713 ![]() ![]() |
For a laugh, buy a can or two of Sea Foam, or similar, follow instructions and see what happens. It might save you hundreds, you never know.
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1813 ![]() ![]() |
Interrogate for fault codes. That will point you in the right direction |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3820 ![]() ![]() ![]() |
Check that the CSOV air change over valve is moving freely and not stuck.
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3552 ![]() ![]() ![]() |
I would put money on it being a boost leak.
Pat Member Since: 20 Nov 2016 Location: Airdrie Posts: 59 ![]() ![]() ![]() |
Hi Thanks for that will look into it |
Carefully check the seams around the plenum donought with a piece of tissue/ kitchen roll looking for sooty black oily tell tale signs of a leak.
Nylands Member Since: 08 Sep 2019 Location: Somerset Posts: 200 ![]() ![]() ![]() |
Hi Mick,
Hi all,
Full easy to follow instructions are in the workshop manual pdf.
Many thanks Mike for that and I’ll look that up and follow. Sometimes I feel like I’m going round in circles but such help is greatly appreciated and reassuring |
I have done a smoke test and could not see any leaks at all
Here is a video
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1754 ![]() ![]() ![]() |
Hi Pat,
