Home > Maintenance & Mods (L405) > Restrictice Performance
Pat
Scotland 2013 Range Rover Autobiography SDV8 Causeway Grey
Hi Looking for some advice/opinions
I have a 2013 L405 4.4SDV8. I understand the turbos are sequential with right hand one operating and normal driving and is a variable vane turbo, the left hand is a standard turbo and only kicks in at approx 2800RPM
When Im driving it performs normally but if i really accelerate hard and under load and take revs above 300RPM my car goes into restrictive mode. Does anybody have any ideas why that is. I have been advised that right hand turbo veins are "sticking" but what i dont understand is this only happens above 300RPM
Post #621511 26th Jan 2022 11:24pm
ilard
For a laugh, buy a can or two of Sea Foam, or similar, follow instructions and see what happens. It might save you hundreds, you never know.
https://www.amazon.co.uk/Sea-Foam-Motor-Tu...B07KRLT3T5 L405 P400e Autobiography (MY2020)... Silicon Silver / Espresso
Post #621701 28th Jan 2022 8:57pm
Mikey
Interrogate for fault codes. That will point you in the right direction Thumbs Up
Post #621703 28th Jan 2022 9:08pm
Baltic Blue
Check that the CSOV air change over valve is moving freely and not stuck.
Bulletin in Wiki.
Mike.
http://www.fullfatrr.com/gallery/albums/us..._TOPIx.pdf G reg 2.5VM Vogue Portofino red 1991- 1999
Post #621708 28th Jan 2022 9:36pm
GGDR
I would put money on it being a boost leak.
we see a lot of these on 4.4TDV8 L322's but less on the 405
that's because part were revised however yours being a 2013 I'd be checking the donut hoses and the throttle body joint .
CSOV sticking is also a possibility.
None of the above are difficult fixes
Good luck
. Cheers, Greg
Post #621712 28th Jan 2022 10:37pm
Pat
Hi Thanks for that will look into it
Post #621748 29th Jan 2022 11:14am
Baltic Blue
Carefully check the seams around the plenum donought with a piece of tissue/ kitchen roll looking for sooty black oily tell tale signs of a leak.
Post #621762 29th Jan 2022 12:19pm
Nylands
United Kingdom 2012 Range Rover Westminster TDV8 Zambezi Silver
Plenum donought
Hi Mick,
This confirms then that my pipes are not the silicon updates thanks. Can you remember where you sourced them and the correct fit etc..
Many Thanks
Post #691593 30th Apr 2024 10:47am
Nylands
Restrictive Performance
Hi all,
Whilst the garage checked my car over last week to find my oil leak, I suspected due to the oil cooler, they found that my "return" booster hose was disconnected! That then was causing my occasional "Restrictive Performance" kicking in and seems OK now. It was local garage, not an independent RR one, but they wondered if that in itself could cause the oil drip so we will see? Probably unlikely but can anyone tell me how to lift the donut out to change the four rubber hoses that can also cause the R Performance cropping up?
Read somewhere on here that it can be lifted one side to replace two and the the other side to do the other without removing the donut altogether. I have the replacement hoses but again this can be done if the oil cooler has to be replaced.
Any guidance would be gratefully received Bow down
Post #693428 27th May 2024 12:43pm
Baltic Blue
Full easy to follow instructions are in the workshop manual pdf.
Post #693429 27th May 2024 1:28pm
Nylands
Plenum Hoses
Many thanks Mike for that and I’ll look that up and follow. Sometimes I feel like I’m going round in circles but such help is greatly appreciated and reassuring Whistle Whistle
Dave
Post #693442 27th May 2024 5:33pm
Pat
Boost leak
I have done a smoke test and could not see any leaks at all
I have noticed when I remove the hose into throttle body it is in horizontal position when engine is off but when I start car I can see throttle body moving on its own every few seconds I don't know if this is normal but when I did same to my brothers identical car his throttle body remained still (in horizontal position)
Post #693490 28th May 2024 3:22pm
Pat
throttle body
Here is a video
go to 5 mins into video
Post #693491 28th May 2024 3:27pm
comports
United Kingdom 2016 Range Rover Autobiography SDV8 Mariana Black
Hi Pat,
Seems there is something in the water.
I'm going through the exact same issue - see https://www.fullfatrr.com/forum/topic70038.html Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #693495 28th May 2024 5:09pm
