Home > Maintenance & Mods (L405) > Restrictice Performance |
ilard Member Since: 21 Oct 2012 Location: London Posts: 712 |
For a laugh, buy a can or two of Sea Foam, or similar, follow instructions and see what happens. It might save you hundreds, you never know.
28th Jan 2022 7:57pm |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1760 |
Interrogate for fault codes. That will point you in the right direction |
28th Jan 2022 8:08pm |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3771 |
Check that the CSOV air change over valve is moving freely and not stuck.
28th Jan 2022 8:36pm |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3544 |
I would put money on it being a boost leak.
28th Jan 2022 9:37pm |
Pat Member Since: 20 Nov 2016 Location: Airdrie Posts: 55 |
Hi Thanks for that will look into it |
29th Jan 2022 10:14am |
Carefully check the seams around the plenum donought with a piece of tissue/ kitchen roll looking for sooty black oily tell tale signs of a leak.
29th Jan 2022 11:19am |
Nylands Member Since: 08 Sep 2019 Location: Somerset Posts: 194 |
Hi Mick,
30th Apr 2024 9:47am |
Hi all,
27th May 2024 11:43am |
Full easy to follow instructions are in the workshop manual pdf.
27th May 2024 12:28pm |
Many thanks Mike for that and I’ll look that up and follow. Sometimes I feel like I’m going round in circles but such help is greatly appreciated and reassuring
27th May 2024 4:33pm |
I have done a smoke test and could not see any leaks at all
28th May 2024 2:22pm |
Here is a video
28th May 2024 2:27pm |
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1698 |
Hi Pat,
28th May 2024 4:09pm |
