Home > Maintenance & Mods (L322) > L322 TD6 2004 EGR delete
sergeiicz
Czech Republic 2002 Range Rover HSE Td6 Epsom Green
Hello if you delete EGR with cooler and EGR thermostat did you bypass that water hose or just blocked it?
I found that winter comes with slow and bad warming engine even after few kms of drive and sometimes stucked in "cold blue field" so I thinking about baypass is not a right way
thank you
Post #613613 24th Nov 2021 8:11am
this 'how to' is from our wiki and explains what to do,
https://www.fullfatrr.com/gallery/thumbnails.php?album=339 ... - .- -.
Post #613614 24th Nov 2021 8:22am
sergeiicz
thank you but its about deleting/removing EGR and not about EGR cooler and water hose
my EGR is already off all that stuff
Post #613615 24th Nov 2021 8:34am
understood...why do you want to remove these?
edit, done a forum search and found this,
https://www.fullfatrr.com/forum/topic51131.html ... - .- -.
Post #613616 24th Nov 2021 8:38am
Sixth post down, Thumbs Up
https://www.fullfatrr.com/forum/post563340.html#563340
Post #613617 24th Nov 2021 8:53am
sergeiicz
already removed as i've got a small leak around that EGR thermostat ...
thank you i found that too, but there is no explanation why to block that coolant hose instead of baypass it but looks like everybody blocking it so i will try that too
make sense at all
thank you
*missclick - this one is for you @stan
Post #613620 24th Nov 2021 9:05am
sergeiicz
thank you i will try to block it too
Post #613622 24th Nov 2021 9:05am
