Home > Maintenance & Mods (L322) > L322 TD6 2004 EGR delete |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35290 |
this 'how to' is from our wiki and explains what to do,
24th Nov 2021 8:22am |
sergeiicz Member Since: 20 May 2020 Location: Caslav Posts: 47 |
thank you but its about deleting/removing EGR and not about EGR cooler and water hose
24th Nov 2021 8:34am |
understood...why do you want to remove these?
24th Nov 2021 8:38am |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3973 |
Sixth post down,
24th Nov 2021 8:53am |
already removed as i've got a small leak around that EGR thermostat ... thank you i found that too, but there is no explanation why to block that coolant hose instead of baypass it but looks like everybody blocking it so i will try that too make sense at all thank you *missclick - this one is for you @stan Last edited by sergeiicz on 24th Nov 2021 9:06am. Edited 1 time in total |
24th Nov 2021 9:05am |
thank you i will try to block it too |
