![]() | Home > Maintenance & Mods (L322) > L322 TD6 2004 EGR delete |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35634 ![]() ![]() |
this 'how to' is from our wiki and explains what to do,
sergeiicz Member Since: 20 May 2020 Location: Caslav Posts: 47 ![]() ![]() ![]() |
thank you but its about deleting/removing EGR and not about EGR cooler and water hose
understood...why do you want to remove these?
Sixth post down, |
already removed as i've got a small leak around that EGR thermostat ... thank you i found that too, but there is no explanation why to block that coolant hose instead of baypass it but looks like everybody blocking it so i will try that too make sense at all thank you *missclick - this one is for you @stan Last edited by sergeiicz on 24th Nov 2021 10:06am. Edited 1 time in total |
thank you i will try to block it too |
