![]() | Home > Maintenance & Mods (L405) > What roof rack? Bars |
jez000 Member Since: 17 Apr 2009 Location: Yorkshire Posts: 744 ![]() ![]() ![]() |
Not sure of what systems you can use without the rails but you can retrofit the rails, here is a link to a set from Powerful uk which has a video on how to fit them:
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8003 ![]() ![]() ![]() |
Fitting rails seems to be the only option unless something has changed recently. Likely the pan roof that's the issue, but not confirmed -
TJH1985 Member Since: 11 Feb 2015 Location: Nottingham Posts: 664 ![]() ![]() ![]() |
I ended up fitting Genuine LR rails and cross bars… be prepared to be amazed how much they can charge for these things. Sold - Bell a 2015 MY16 Loire Blue Autobiography 4.4 SDV8
If you have a tow bar fitted then I'd use that instead
Agreed I have both and it’s much easier to put stuff on the back…It’s a long way up…
Crasher242 Member Since: 07 Mar 2019 Location: Warwickshire Posts: 138 ![]() ![]() ![]() |
I have the pano roof and fitted a set of roof bars to mine.
urman Member Since: 06 Oct 2024 Location: Bratislava Posts: 5 ![]() ![]() |
hoppy_70 Member Since: 04 Apr 2010 Location: Peoples Republic of Mancunia! Posts: 870 ![]() ![]() ![]() |
I used the Thule system and bought the feet for a RRS and the widest Thule wing bars. Did about a 1000 miles to Cornwall and back with a box in without issue. I think the reason they don’t show them as compatible is because the pan roof won’t open with it on (it does on the RRS).
Same feet (but with shorter bars) on my RRS (can you tell I like velocity blue |
