Home > Maintenance & Mods (L405) > What roof rack? Bars
Stacey007
Hello
My RR has no roof rail system for the roof bars, what options do I have for fitting roof bars? (L405)
Is it simply a thule type set up.
Thanks
Post #611511 3rd Nov 2021 6:19pm
jez000
United Kingdom 2011 Range Rover Vogue SE TDV8 Bournville
Not sure of what systems you can use without the rails but you can retrofit the rails, here is a link to a set from Powerful uk which has a video on how to fit them:
https://www.powerfuluk.com/range-rover-l40...black.html 2021 P400 Silicon Silver AB
Gone 2011 Bournville TDV8 VSE
Gone 2008 Black Canadian HSE LUX
Post #611517 3rd Nov 2021 6:47pm
Fitting rails seems to be the only option unless something has changed recently. Likely the pan roof that's the issue, but not confirmed -
https://www.fullfatrr.com/forum/topic53335.html
https://www.fullfatrr.com/forum/topic18718.html
Post #611523 3rd Nov 2021 7:42pm
TJH1985
I ended up fitting Genuine LR rails and cross bars… be prepared to be amazed how much they can charge for these things. Sold - Bell a 2015 MY16 Loire Blue Autobiography 4.4 SDV8
Previously George a 2007 MY07 Java Black VSE 3.6 TDV8
Previously a 04 MY04 Defender 90 Sad
Post #611543 3rd Nov 2021 8:50pm
If you have a tow bar fitted then I'd use that instead
https://www.fullfatrr.com/forum/topic41146.html
If not, then it's a hefty investment either way.
Post #611545 3rd Nov 2021 8:55pm
TJH1985
Agreed I have both and it’s much easier to put stuff on the back…It’s a long way up…
Post #611547 3rd Nov 2021 9:16pm
Crasher242
I have the pano roof and fitted a set of roof bars to mine.
I put some pics up of my install - hopefully this link to the post should work
https://www.fullfatrr.com/forum/post565329.html#565329
Regards Current
Vogue SE 4.4 SDV8
Previous highlights
Many Mini's!
Audi S8
Audi A6 Avant (the petrol guzzling Bi-turbo)
Subaru H6 3.0 Estate
Peugeot 406 Coupe V6
Audi 80 Quattro Sport
Post #611718 5th Nov 2021 5:30pm
urman
Slovakia
The car had a bare roof.
1) That is why we need rails first. To the rails need covers under them with holes. Rails - only the original, it is clear. 650$ rails: VPLGR0079 Overlays: 300$ VPLGR0097
2) Started monitoring the crossbars (trunk). It comes out only the original (Thule production) VPLGR0102. In general on boxes and luggage racks on L405 materials just a minimum. There is a post on the drive here and all. I google, find a picture of Kiev company on luggage racks. Worth on l405 luggage rack Thule Wingbar Evo: carstyle.ua/en/bagazhnik-...itan-na-land-rover-vogue/
Freshly developed in 2018.
The price tag by the way is only 100$ cheaper than the original.
but a new modern development.
3) Box. Here long ago decided, even on Cayenne wanted to put. Box ... Porsche! This is OEM production from Thule. In reality, it is a top box Thule Excellence XT with phenomenal characteristics: 520(!) liters at a height of 40cm, double-sided opening and all other pluses. Thule itself has discontinued it and even the newest Vector series has worse parameters. Yes, Porsche doesn't have a flashlight, net and a couple of other little things. But the last price on these Thule's were $2,000 each. And the Porsche is $1,250.
In general, as a result, I have a phenomenal 520l at a height of 40cm, and this means a lot, for example in parking lots (photo below).
Now about impressions: up to 100 there is no noise at all, further increases, but not critical. 140-160 it is possible to go. 180-begins some whistling. Total up to 160 it is possible to drive without strain at all.
Post #702160 14th Oct 2024 4:39pm
hoppy_70
England 2018 Range Rover Autobiography 2.0 PHEV Loire Blue
I used the Thule system and bought the feet for a RRS and the widest Thule wing bars. Did about a 1000 miles to Cornwall and back with a box in without issue. I think the reason they don’t show them as compatible is because the pan roof won’t open with it on (it does on the RRS).
No issues as long as you remember not to open it with the bars on!
 My Previous RR's!
2018 P400e Autobiography
2008 TDV8 Vogue
2006 TD6 Vogue
2007 TDV8 Vogue
2007 RRS (I know, it doesn't count!)
2005 4.4 Vogue on LPG
2005 TD6 Vogue
2003 4.4 Vogue
2001 4.6 HSE
2000 2.5 DHSE
1999 4.6 HSE
1997 4.6 HSE on LPG
1995 2.5 DSE
1989 3.9 EFI classic
1988 3.5 EFI classic
Post #702243 15th Oct 2024 7:11pm
hoppy_70
Same feet (but with shorter bars) on my RRS (can you tell I like velocity blue Very Happy )
 My Previous RR's!
2008 TDV8 Vogue
2006 TD6 Vogue
2007 TDV8 Vogue
2005 TD6 Vogue
2003 4.4 Vogue
2001 4.6 HSE
2000 2.5 DHSE
1999 4.6 HSE
1997 4.6 HSE on LPG
1995 2.5 DSE
Post #702245 15th Oct 2024 7:14pm
