Home > Maintenance & Mods (L322) > Retro fitting Paddle Shift to early L322
Page 9 of 14 <123 ... 8910 ... 121314>
allisong
Quote:
it was soon apparent that the wires could not be added to the slip ring so we had to go with the idea of the wireless way,
Hi, just for reference - there are enough slip ring contacts if you rationalise what is in use, see posts made earlier on how. No need for radio remote etc., just some re-wiring, I have it all working, steering switches, paddle switches and steering heating.
Basically the existing wiring consists of two +ve supplies and two earths through the slip ring, by combining both +ves and earths into one for each, two tracks are freed off for the paddle shifts.
Best regards!
Post #74446 1st Aug 2011 7:47pm
x7mpp
Hi, Your method sounds a more acceptable solution. Do you have the full instructions on how to do the retro fit of the paddles?
Post #75535 10th Aug 2011 4:58pm
Stryke
Is there a kit available yet?
Would be a perfect mod for the S/C Very Happy
Post #75822 11th Aug 2011 9:16pm
pretlove
stryke....im sure for the right money someone will build you one .. Whistle "RANGEISM WILL NOT BE TOLERATED"
Post #75852 12th Aug 2011 2:04am
x7mpp
Im looking to go the hard wired way as opposed to wireless, any clear instructions anywhere?
Post #75855 12th Aug 2011 8:00am
Hi, i have an 06 FFSC... Is the gearbox connector the same as Matts picture even though mine's a later facelifted car? Paddles should arrive on saturday from dealer... Busy weekend ahead!
Post #75859 12th Aug 2011 8:32am
pretlove
@x7 you need to contact allisong as he has hard wired his
@cam-tech im sure it will be the same but am not aware if anyone has done a facelift model yet "RANGEISM WILL NOT BE TOLERATED"
Post #75868 12th Aug 2011 10:16am
mattstevenson2005
United Kingdom 2003 Range Rover Autobiography 4.4 V8 Java Black
Hi Craig, i dont have access to any of the 2006+ wiring diargams to 100% confirm that the wiring is the same, but i am asuming that you have the same style interior as mine e.g. pre 2007 upgrade. So the gearshift should be the same, if you just take a look a the wiring when you take apart the centre console and just look at the purple connector and trace the wires back to the microswitch that does the original upshift/downsift of the gearshift. Just make sure that the wires are correct before taping into them, most tiptronic systems work on the same principle of just shorting to ground to make the connection to either upshift or downshift the transmission.
Take some pics if you can and if you need any help PM me and i will send you my mobile number and i can try and talk you though it.
Matt
Post #75883 12th Aug 2011 11:48am
Matt, thanks for coming back to me... I have looked and yes the purple plug seems to be the same as the earlier models... And yes mine has the earlier trim but with the later touch screen nav...
Very busy weekend ahead, extend piano wood inside (including paddle shift to new piano wheel), fit 2011 facelift front & rear, fit 2011 overfinch spoilers/bumpers etc, fit 22's, then hopefully the new lowering module will arrive early next week to complete! Shocked Shocked Shocked
Post #76030 13th Aug 2011 8:57am
mattstevenson2005
wow!!! this must be costing you a small fortune!!! i would love to do the 2011 facelift to my car!
Matt
Post #76037 13th Aug 2011 9:44am
pretlove
you'll have to post before and after pics ...... i want the facelift as well but funds wont allow it at the moment Big Cry "RANGEISM WILL NOT BE TOLERATED"
Post #76043 13th Aug 2011 10:15am
Lukily i own a RR upgrades and maintenance business in Gloucestershire so we've done to my last three 322's. But yes your right its alot of work.
Neutral
Can anyone tell me how to place pictures on here? As we have lots on file...
Post #76114 13th Aug 2011 9:39pm
pretlove
may i just add if you have a hse without the rear heated seats then this wire will not be any good for you as there is no power to it
instead get the power from the wire that goes to the aux fan just underneath this plug
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  "RANGEISM WILL NOT BE TOLERATED"
Post #76662 18th Aug 2011 3:59pm
JustinP
Neutral
Either up load them to the fullfatrr.com gallery and copy the img tag or up load them to an external website and use the 'Img' button to add them to your post.
If you want to use the fullfatrr.com gallery you may need to reduce the image size if they are too large to upload.
Feel free to pm me with any questions if you need more help Thumbs Up
Post #76670 18th Aug 2011 5:36pm
Finally finished the upgrades to the SC including the paddleshift kit... WOW works great! Gone the hardwired route and on a trip upto Silverstone this weekend it worked brilliantly for the 'A road' overtakes. Just leave it in auto for the majority of the trip, then when you want a little more control for overtaking knock it into sport and change with the paddles... Brilliant!
A further note, to answer some earlier points. I used the manual mode on my last FF TD6 when towing my tri axle car transporter as the gearbox had a tendancy to hold gears on long uphill climbs. Have yet to tow with the SC but am expecting the same hence the paddles...
Will post pics of 2011 conversion, overfinch bumper and other mods shortly... Thumbs Up Thumbs Up Thumbs Up
A BIG thanks to Matt for the you tube vids... Made my job significantly easier... Bow down
Post #77037 22nd Aug 2011 8:31am
