Home > Maintenance & Mods (L322) > Retro fitting Paddle Shift to early L322
Page 8 of 14 <123 ... 789 ... 121314>
Ajay(UK)
United Kingdom 2015 Range Rover Autobiography SDV8 Indus Silver
Baben wrote:
In the 2010+ it is plug and play - it was designed as an option, just never installed
I thought this still had to be coded with a faultmate MSV Question
Andy. 2015 L405 SDV8 Autobiography, Indus Silver with Black Pack.
SWMBO: 22MY Defender 110 HSE X Dynamic, Gondwana Stone.
Gone: 2014 Discovery 4 HSE Luxury Firenze Red
Gone: 2006MY Java Black TD6 Autobiography
Gone: 2013 Jaguar XKR Convertible, Italian Racing Red with Ivory Seats
Gone: 2010MY Stornoway Grey TDV8 Vogue SE with RSE
Gone: 2008 Disco 3 HSE, Hybrid Tv + Retro-fit RSE System & DVD
Gone: 2003 Epsom Green 4.4i Vogue, LPG, Mk4 Nav, BMW Bluetooth Phone, Hybrid Tv Tuner,
Post #72749 17th Jul 2011 7:34pm
allycraven
allisong wrote:
I have a 2007 Range Rover with heated steering wheel so do not have the additional circuits available through the "clock spring" as JLR call it, BUT studying the wiring diagrams I could see that the heated steering wheel wiring has a seperate ground and 12v supply wire (from the ignition) to the normal steering wheel switches. This is to allow it to be fused seperately I guess.
Normal swiches are off a 5 amp fuse and the steering heating off a 10 amp fuse. SO by using the ground and supply wires for the heated steering wheel only (wiring the normal switches across to this supply on the steering wheel side) I was able to free off two tracks from front to back to use for the paddle shifts. Makes the 5 amp fuse redundant and the 10A fuse is large enough.
Hence you CAN fit paddle shifts to older cars with a heated steering wheel with the existing hardware - no need for RF remotes etc. Much easier!
Would a MY07 not have a CAN BUS link from the steering wheel controls, or was this left on the old Beemer iBUS system until the MY10 wheel change?
Post #72817 18th Jul 2011 3:27pm
allisong
According to the wiring diagrams the 2007 is still iBus (called DS2 bus in IDS), no CAN to the steering wheel until 2010 with the new buttons etc.
Post #72901 19th Jul 2011 8:42am
Baben
South Africa 2014 Range Rover Autobiography SDV8 Luxor
Andy.
Yes. So that means plug n play to me, ie no hardware modification required. You plug in the paddles and tell the car they exist, and they work
Post #73175 21st Jul 2011 1:10am
Ajay(UK)
Baben wrote:
Andy.
Ah so not plug and play for most since a faultemate MSV costs the best part of £1000 unless you can find someone with a multi-vehicle licence which for 2010MY is probably rarer than an uncooked steak Laughing
I think this mod can wait Rolling Eyes
Post #73218 21st Jul 2011 11:34am
Baben
still not with you? plug n play means its easy. I never said it was cheap
Post #73225 21st Jul 2011 12:02pm
pretlove
a trip to an indi should sort that part out for around £50 Thumbs Up "RANGEISM WILL NOT BE TOLERATED"
Post #73226 21st Jul 2011 12:02pm
Ajay(UK)
Our opinions of what is classed as "plug & play" must differ then as I have always felt that to be plug and play you just plug it in and it works - such as upgrading a tv tuner from analogue to digital.
Having to then hook up a faultmate MSV (or equivalent), read the CCF, find the correct section and change the option to say paddle shift is fitted, save and rewrite the CCF, for most does not constitute plug and play. An easy job to retrofit the paddles - agreed - but its a bit more than plug and play. Whistle
pretlove - I also have reservations as to an indi having a 2010MY licence as why would they need one yet with all vehicles still under warranty? I am happy to be proved wrong though Wink
Post #73242 21st Jul 2011 12:38pm
Baben
OK you win
Post #73243 21st Jul 2011 12:42pm
pretlove
good point ajay i could check with my indi for you but the only problem is he is based in essex "RANGEISM WILL NOT BE TOLERATED"
Post #73255 21st Jul 2011 2:12pm
Ajay(UK)
It would still be worth a call as you never know there maybe a few 2010MY owners that might want flappy paddles Laughing
Essex is not too far - just not a regular stomping ground for me Whistle
Post #73289 21st Jul 2011 7:28pm
pretlove
ill give em a bell tomorrow for you and see what he says Thumbs Up "RANGEISM WILL NOT BE TOLERATED"
Post #73291 21st Jul 2011 7:43pm
Baben
there are other reasons (apart from paddles) for me buying a faultmate with a 2010 license.
Stuff the dealers can't (or won't ) do:
1) daytime driving lights enable/disable
2) service indicator enable
3) nav on the go (although I cant get this working yet Sad )
4) alarm chirp on
5) modify TPMS settings (so far with little effect Big Cry)
6) because I actually use my vehicle offroad in countries in Africa where there is no support available
Post #73357 22nd Jul 2011 10:19am
daveo
had some time over the weekend so i thought i would go back and tidy up the paddle shift change install, when i started it with matt it was more trile and error to get things wright, it was soon apparent that the wires could not be added to the slip ring so we had to go with the idea of the wireless way,
my install was a little messy and used the battery supplied, i wanted to hard wire it and remove the battery and find,what had been a prob for a few people including my self the best place to put the tx with out damaging it.
i used a plug so i could if needed unplug the tx unit, left the black ground wire loose so i could fix it to ground via a screw
use the correct colour wires, this is a big no,no i hate using wrong colour wires but sometimes you just go with what you have at the time
then covered the whole unit with a thick heat shrink, again i used masking tape the first time round as it was all i had.
i used a flat 4 way computer connector,from maplins, on the end of the paddel loom, and after finding a good place to mount the tx board the loom needed no modding.
a little bit of double sided tape to hold the connector in the right place
this time i did take the wheel of, it made it far easier to get it right, the air bag fits just fine, just need to connect the red to the live on the heated wheel and screw the ground down.
this turned out to be one of the best mods i have done, its a simple and cheap mod and you end up with great extra, :D
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  V8 facelift Range Rover Autobiography 22" wheels.
Post #74362 31st Jul 2011 9:16pm
pretlove
tidy job daveo Thumbs Up Bow down "RANGEISM WILL NOT BE TOLERATED"
Post #74412 1st Aug 2011 1:07pm
