Home > Maintenance & Mods (L322) > Retro fitting Paddle Shift to early L322 |
x7mpp Member Since: 10 Aug 2011 Location: UK Posts: 5 |
Hi, Your method sounds a more acceptable solution. Do you have the full instructions on how to do the retro fit of the paddles? |
10th Aug 2011 4:58pm |
Stryke Member Since: 16 Nov 2010 Location: UK Posts: 262 |
Is there a kit available yet?
11th Aug 2011 9:16pm |
pretlove Member Since: 10 Feb 2011 Location: Bas vegas Posts: 1865 |
stryke....im sure for the right money someone will build you one .. "RANGEISM WILL NOT BE TOLERATED"
12th Aug 2011 2:04am |
Im looking to go the hard wired way as opposed to wireless, any clear instructions anywhere? |
12th Aug 2011 8:00am |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16265 |
Hi, i have an 06 FFSC... Is the gearbox connector the same as Matts picture even though mine's a later facelifted car? Paddles should arrive on saturday from dealer... Busy weekend ahead! |
12th Aug 2011 8:32am |
@x7 you need to contact allisong as he has hard wired his
12th Aug 2011 10:16am |
mattstevenson2005 Member Since: 01 Jan 2011 Location: Manchester, UK Posts: 737 |
Hi Craig, i dont have access to any of the 2006+ wiring diargams to 100% confirm that the wiring is the same, but i am asuming that you have the same style interior as mine e.g. pre 2007 upgrade. So the gearshift should be the same, if you just take a look a the wiring when you take apart the centre console and just look at the purple connector and trace the wires back to the microswitch that does the original upshift/downsift of the gearshift. Just make sure that the wires are correct before taping into them, most tiptronic systems work on the same principle of just shorting to ground to make the connection to either upshift or downshift the transmission. Take some pics if you can and if you need any help PM me and i will send you my mobile number and i can try and talk you though it. Matt |
12th Aug 2011 11:48am |
Matt, thanks for coming back to me... I have looked and yes the purple plug seems to be the same as the earlier models... And yes mine has the earlier trim but with the later touch screen nav...
13th Aug 2011 8:57am |
wow!!! this must be costing you a small fortune!!! i would love to do the 2011 facelift to my car! Matt |
13th Aug 2011 9:44am |
you'll have to post before and after pics ...... i want the facelift as well but funds wont allow it at the moment "RANGEISM WILL NOT BE TOLERATED"
13th Aug 2011 10:15am |
Lukily i own a RR upgrades and maintenance business in Gloucestershire so we've done to my last three 322's. But yes your right its alot of work.
13th Aug 2011 9:39pm |
may i just add if you have a hse without the rear heated seats then this wire will not be any good for you as there is no power to it
18th Aug 2011 3:59pm |
JustinP Member Since: 24 Oct 2010 Location: Cambridge Posts: 889 |
Either up load them to the fullfatrr.com gallery and copy the img tag or up load them to an external website and use the 'Img' button to add them to your post. If you want to use the fullfatrr.com gallery you may need to reduce the image size if they are too large to upload. Feel free to pm me with any questions if you need more help Gone - Range Rover Supercharged 2006 |
18th Aug 2011 5:36pm |
Finally finished the upgrades to the SC including the paddleshift kit... WOW works great! Gone the hardwired route and on a trip upto Silverstone this weekend it worked brilliantly for the 'A road' overtakes. Just leave it in auto for the majority of the trip, then when you want a little more control for overtaking knock it into sport and change with the paddles... Brilliant!
22nd Aug 2011 8:31am |
