Home > Maintenance & Mods (L322) > Retro fitting Paddle Shift to early L322
Page 7 of 14 <123 ... 678 ... 121314>
mattstevenson2005
United Kingdom 2003 Range Rover Autobiography 4.4 V8 Java Black
allisong wrote:
I have a 2007 Range Rover with heated steering wheel so do not have the additional circuits available through the "clock spring" as JLR call it, BUT studying the wiring diagrams I could see that the heated steering wheel wiring has a seperate ground and 12v supply wire (from the ignition) to the normal steering wheel switches. This is to allow it to be fused seperately I guess.
Normal swiches are off a 5 amp fuse and the steering heating off a 10 amp fuse. SO by using the ground and supply wires for the heated steering wheel only (wiring the normal switches across to this supply on the steering wheel side) I was able to free off two tracks from front to back to use for the paddle shifts. Makes the 5 amp fuse redundant and the 10A fuse is large enough.
Hence you CAN fit paddle shifts to older cars with a heated steering wheel with the existing hardware - no need for RF remotes etc. Much easier!
Nobody ever said you can’t use the existing wire but it’s not really recommended as now when the heating element pops in the wheel and blows the fuse (which is quite a common thing) you won’t just lose the heating function you will lose all steering wheel switch control too lol also what happens now if you have a fault in your steering wheel wiring there is now no fuse inline to break the circuit in the case of shorting as the 10amp fuse wont blow for a 5amp circuit, love you enthusiastic approach especially when it’s your first post on here lol
Post #70347 28th Jun 2011 1:48pm
Baben
South Africa 2014 Range Rover Autobiography SDV8 Luxor
It is an intriguing possibility Allisong. Perhaps one could fuse the heating element inside the wheel so that if it pops it doesn't pop the whole lot - this assumes you replace the original 10A with perhaps a 15A and then fuse at 10A at the heating element. Depends whether the clock spring can handle 15A thru that circuit designed for 10A. I would be surprised if it couldn't.
Post #70368 28th Jun 2011 5:05pm
pretlove
wireless is good Thumbs Up ...........as they say dont fix it if it aint broke...........plus for me i dont have the heating element so couldnt do it that way if i wanted to...........but still if it works for you well done "RANGEISM WILL NOT BE TOLERATED"
Post #70372 28th Jun 2011 6:12pm
robbo770
Scotland 2005 Range Rover Supercharged 4.2 SC V8 Zambezi Silver
Well I have managed to get the wireless working on my V8, I even remote powered the Transmitter so no worries about battery going flat.
but the thing I have not done is power up the paddle leds, these are powered in one direction of + / - where as the transmitter with being powered on mine now, works in the reverse polarity, so if I was to connect the led, I would blow my paddles printed circut boards, I know I tried!!!!!,
so these wil be not used till I isolate them another day and bring there own 2 cable to the power and earth connections I have now in the steering wheel.
MASSIVE THANKS TO:
MATT / DAVEO / JONNO ? PRETLOVE
as the last photo help me greatly
Cheers from a happy paddler!! Thumbs Up Thumbs Up Thumbs Up Thumbs Up Current vehicles
4.2 SC FFRR RSE 2010- facelift
Range Rover Evogue Dynamic Lux
Gone
Rejected RRS my14.5 nightmare
Disco B4 XXV convert
Freelander 06 SE
06 RFFRR 4.2 SC Vogue RSE
Audi A8 4.2Tdi Quattro (hated with a vengence!!)
54 FFRR 2005 model V8 4.4 Cobra Variant
53 Mitsubishi Shogun V6
Post #70753 30th Jun 2011 10:14pm
lurking on this thread and i have a question, what are you guys going to use the paddles for as the FFRR is an auto and was designed to be driven like one..
Post #70767 1st Jul 2011 8:01am
robbo770
well scarey, Mr. Green
when you have a V8 with 22" rims, the word off roader, become road killer, as mine loves a roasting along any road and the paddle shift makes this even more fun to do, so this should even on a Td6 make the driving experience a exciting occurance!!!
Thumbs Up Thumbs Up
no its not a new 5 litre SC but that no reason why it can't be one almost... Current vehicles
Gone
Freelander 06 SE
Post #70768 1st Jul 2011 8:07am
understood , but isnt there a manual mode on the gear stick for that..
Post #70769 1st Jul 2011 8:14am
mattstevenson2005
yer but the gearshift is stupid in manual mode its too far over to be of any use lol
Post #70841 1st Jul 2011 6:38pm
pretlove
thats true it is to far over......also what can i say boys and there toys Thumbs Up
if im really honest ive only used it twice and may never use it again but i have it and thats good Cool "RANGEISM WILL NOT BE TOLERATED"
Post #70842 1st Jul 2011 6:40pm
allisong
All, with respect to using the heated steering wheel supply for all the switches, well yes indeed if the heating element shorts then the 10 Amp fuse blows and all the switches stop working, not that bad, I have a new steering wheel and don't use the heating that often and would not expect the element to blow. I would also expect it to blow "open circuit" not "short circuit" anyhow. If it does short circuit you would simply have to replace the fuse to get the switches working and at a later date you have the issue of having to repair the steering heating element anyhow. (If the element shorts then I would expect the steering heating circuit board would "fry" also looking at the design).
Getting back to reality, I measured the actual current used: The heated steering wheel takes 5 Amp when cold dropping to 2 Amp when warm and the other switches take less than 0.75 Amp so no need to upgrade the fuse. Total load is well less than 10 Amps. If you want to be paranoid and protect the ordinary switches separately then it would be easy to add an inline fuse in the wiring behind the airbag. I don't see the need for this quite honestly.
Please be aware that the tracks in the "clock spring" for the heated steering wheel supply and ground are thicker and more robust than all the others, hence the reason why these are the best to use as they can handle more current.
The option of doing it this way works really well - now used daily and I am certainly very happy with this approach.
So for those who want to avoid wireless and who want to retain full steering wheel heating, there is a valid option.
Geoff.
Post #70881 2nd Jul 2011 5:09am
pretlove
well explained geoff Thumbs Up
and welcome to the forum "RANGEISM WILL NOT BE TOLERATED"
Post #70894 2nd Jul 2011 9:54am
robbo770
well here is the detailed photo's of the steering wheel conversion that I did to avoid any battery use , so its ingnition powered via the heate steering wheel circut.
POWER up Connections shown here
The critical Paddle wiring connection solder postions!!
another shot of the RF Paddle wiring
The shot of the wiring connections in the steering wheel base, the power take off from the red positive for the Heated steering wheel, and the drilled and tapped earth point top right with 4mm brass screw to ensure good connection!!
Hope this helps anyone still trying to wire it all up!
cheers Rob
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Current vehicles
Gone
Freelander 06 SE
Post #72660 16th Jul 2011 12:49pm
robbo770
I am helping a oversea FF member convert his TDV8 3.6
but need a photo of the gearbox connection plug wiring and colour code for the up and down shift wires to help his sparky install it fast can anyone assist??
cheers Rob Current vehicles
Gone
Freelander 06 SE
Post #72691 16th Jul 2011 8:47pm
Baben
Well, in addition to making the on-road use the the vehicle a lot more snappy when pressing on, I use the paddles off-road as well. In thick sand it gives you immediate availability of a lower or higher gear exactly when you need it without waiting for the box to react, ie you don't lose momentum before you grab the lower gear.
The gear control in my vehicle has manual, just like most of the newer vehicles have manual shift. We are using the same control but just adding the steering paddles. In the 2010+ it is plug and play - it was designed as an option, just never installed
Post #72702 17th Jul 2011 4:43am
i like to stick the lever in 'd' and drive...if i want to mess about with gearing , i would have got one of those 'manual' cars i keep hearing about..
Post #72705 17th Jul 2011 8:59am
