![]() | Home > Technical (L405) > Battery disconnect |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3870 ![]() ![]() ![]() |
I joined the RAC so I wouldn’t have to manhandle the 22” spare if I had a puncture (actually used ‘em once - worked a treat) I’d like to do a battery reset (disconnect) to try and fix something but the battery is under the spare is there another way or will I have to get the spare out? Geoff |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35492 ![]() ![]() |
the WM says to take the spare out and then disconnect the negative cable....remember to turn the steering wheel fully left and then right with the engine running when you reconnect.. ... - .- -.
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7971 ![]() ![]() ![]() |
There's a lifter you can buy for the spare if you don't already have one -
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1215 ![]() ![]() ![]() |
It resets the steering angle sensor, after such things as a battery disconnect, having wheels off the ground during work etc. See the below |
from WM,
154JON Member Since: 31 Mar 2019 Location: Essex Posts: 130 ![]() ![]() ![]() |
Thanks not heard that mentioned before. |
Steering L & R is only valid on the early MK3 or L322 Stan... |
according to the WM it is...only qouting whats written. ... - .- -.
How strange… |
Landphil Member Since: 03 Oct 2016 Location: U.K. Posts: 119 ![]() ![]() |
The video is an older model but it wouldn’t be the first time the WM was subject to a “cut and paste” error.
Dixy Member Since: 09 Apr 2009 Location: Somerset Posts: 1102 ![]() ![]() |
Mine is coming up to 6 years old and I am considering fitting new batteries as a proactive move. is it straight forward. letters not necessarily in the right order |
Ooopppsss, sorry folks, when I posted the video about the steering angle sensor reset, I did not notice that Supershuttle's car was not an old lump like mine.
Thanks to all who took the trouble to reply, the steering lock to lock thing costs me nowt so I'll do it anyways. |
