Home > Technical (L405) > Battery disconnect |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3779 |
I joined the RAC so I wouldn’t have to manhandle the 22” spare if I had a puncture (actually used ‘em once - worked a treat) I’d like to do a battery reset (disconnect) to try and fix something but the battery is under the spare is there another way or will I have to get the spare out? Geoff |
3rd Oct 2021 8:36am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35279 |
the WM says to take the spare out and then disconnect the negative cable....remember to turn the steering wheel fully left and then right with the engine running when you reconnect.. ... - .- -.
3rd Oct 2021 10:27am |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7926 |
There's a lifter you can buy for the spare if you don't already have one -
3rd Oct 2021 10:34am |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1181 |
It resets the steering angle sensor, after such things as a battery disconnect, having wheels off the ground during work etc. See the below
3rd Oct 2021 2:14pm |
from WM,
3rd Oct 2021 2:52pm |
154JON Member Since: 31 Mar 2019 Location: Essex Posts: 129 |
Thanks not heard that mentioned before. |
3rd Oct 2021 10:54pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16284 |
Steering L & R is only valid on the early MK3 or L322 Stan...
3rd Oct 2021 11:23pm |
according to the WM it is...only qouting whats written. ... - .- -.
4th Oct 2021 5:51am |
How strange… |
4th Oct 2021 7:33am |
Landphil Member Since: 03 Oct 2016 Location: U.K. Posts: 119 |
The video is an older model but it wouldn’t be the first time the WM was subject to a “cut and paste” error.
4th Oct 2021 10:16am |
Dixy Member Since: 09 Apr 2009 Location: Somerset Posts: 1092 |
Mine is coming up to 6 years old and I am considering fitting new batteries as a proactive move. is it straight forward. letters not necessarily in the right order |
4th Oct 2021 10:47am |
Ooopppsss, sorry folks, when I posted the video about the steering angle sensor reset, I did not notice that Supershuttle's car was not an old lump like mine.
4th Oct 2021 11:07am |
Thanks to all who took the trouble to reply, the steering lock to lock thing costs me nowt so I'll do it anyways. Geoff |
4th Oct 2021 2:35pm |
