Home > Technical (L405) > Battery disconnect
supershuttle
Battery disconnect
I joined the RAC so I wouldn’t have to manhandle the 22” spare if I had a puncture (actually used ‘em once - worked a treat) I’d like to do a battery reset (disconnect) to try and fix something but the battery is under the spare is there another way or will I have to get the spare out? Geoff
Post #607997 3rd Oct 2021 8:36am
the WM says to take the spare out and then disconnect the negative cable....remember to turn the steering wheel fully left and then right with the engine running when you reconnect.. ... - .- -.
Post #608014 3rd Oct 2021 10:27am
There's a lifter you can buy for the spare if you don't already have one -
https://www.fullfatrr.com/forum/topic35224.html
Post #608016 3rd Oct 2021 10:34am
154JON
United Kingdom 2015 Range Rover Vogue SDV8 Santorini Black
HI stan
What does turning the steering wheel fully left and then right with the engine running when you reconnect the battery do.
Thanks
Post #608026 3rd Oct 2021 11:39am
Merchy
It resets the steering angle sensor, after such things as a battery disconnect, having wheels off the ground during work etc. See the below Thumbs Up
Post #608051 3rd Oct 2021 2:14pm
from WM,
After connecting the battery, the steering wheel must be turned to
full left-hand and full right-hand lock with the engine running. This
allows the dynamic stability control system to calibrate the steering
wheel position. Failure to follow this instruction will result in a
variety of instrument cluster warning lights being illuminated.
Post #608053 3rd Oct 2021 2:52pm
154JON
Thanks not heard that mentioned before. Very Happy
Post #608139 3rd Oct 2021 10:54pm
Steering L & R is only valid on the early MK3 or L322 Stan... Thumbs Up
So, not valid on the 405 sir Bow down Bow down Bow down
Post #608141 3rd Oct 2021 11:23pm
according to the WM it is...only qouting whats written. ... - .- -.
Post #608146 4th Oct 2021 5:51am
How strange… Bow down Thumbs Up
Post #608153 4th Oct 2021 7:33am
Landphil
The video is an older model but it wouldn’t be the first time the WM was subject to a “cut and paste” error.
That said it can do no harm to follow it.
Post #608166 4th Oct 2021 10:16am
Dixy
2016 Range Rover Vogue SDV8 Loire Blue
Mine is coming up to 6 years old and I am considering fitting new batteries as a proactive move. is it straight forward. letters not necessarily in the right order
Post #608170 4th Oct 2021 10:47am
Merchy
Ooopppsss, sorry folks, when I posted the video about the steering angle sensor reset, I did not notice that Supershuttle's car was not an old lump like mine.
Note to self -
Will try to pay more attention in the future, before people start wondering about my mental facilities, ....probably way to late for that though Big Cry Rolling with laughter
Post #608172 4th Oct 2021 11:07am
supershuttle
Thanks to all who took the trouble to reply, the steering lock to lock thing costs me nowt so I'll do it anyways. Very Happy Very Happy Geoff
Post #608191 4th Oct 2021 2:35pm
