Home > Technical (L322) > 4.4 tdv8 won’t start (not battery)
Page 1 of 3 123>
coopss
Odd one - go to start but it clunks (starter engages but won’t turn over). No error messages on the dash aside from the low range light flashing. Tried a new battery to no avail. I’ll copy/paste the codes later to see if that helps.
I’d did this once last week but then started and drove twice since. Any thoughts chaps? Tried resetting the error message but no joy.
Any help appreciated 1995 4.6 v8, green/tan (long gone)
2005 4.8iS X5, blue/black
2011 4.4 tdv8, black/black (gone)
2003 3.0d X5, Oxford green/black/manual
2021 p575 SVR, BR green/vintage tan
Post #608065 3rd Oct 2021 4:16pm
mjdronfield
Sounds like the starter motor… seems to be something of a known issue.
Mine does it sometimes. Another press of the start button and all is good.
There are a few threads on it.
Contacts tend to get carboned up inside the starter.
Some have stripped them down and cleaned them up… some have just fitted a new starter.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #608079 3rd Oct 2021 4:50pm
coopss
Hope not as it’s just had a brand new LR one! Second one in 14 months. Going down to read the codes shortly.. 1995 4.6 v8, green/tan (long gone)
Post #608082 3rd Oct 2021 4:53pm
mjdronfield
Ah, probably not that either then….
I read sometimes the joins in the cabling can be an issue, but I’m not an expert.
Just from reading on the forum.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #608092 3rd Oct 2021 5:53pm
DrRob
Could be cable joins.
You could try and extra earth from battery to chassis as a test but not sure if that's OK on these motors. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #608099 3rd Oct 2021 6:16pm
coopss
It just started. Odd. Here are the error codes
BCM-Body Control
B100D-87 (2Cool Column lock authorisation - Bus signal/message failure - missing a message
( on 02-10-2021 20:22:31 at 250993 km )
B100D-67 (2Cool Column lock authorisation - Algorithm based failure - signal is incorrect after the event
( on 02-10-2021 20:22:11 at 250993 km )
B11DB-87 (2F) Battery monitoring module - Bus signal/message failure - missing a message
( on 03-10-2021 20:22:05 at 0 km )
DABM-Digital Audio
U3000-04 (2F) Control module - General failure information - system internal failure
( on 03-10-2021 20:22:21 at 250993 km )
GSM-Gear Shift
U0422-81 (2E) Invalid data received from the body control module - Bus signal/message failure - invalid serial data received
( on 03-10-2021 20:24:03 at 250993 km )
PCM-Engine TDV8 4.4L
U0416-68 (2A) Invalid data received from vehicle dynamics control module - Algorithm based failure - event information
( on 03-10-2021 20:24:03 at 250994 km )
( on 03-10-2021 20:22:26 at 250994 km )
P065B-16 (2F) Generator control - circuit range/performance - General electrical failure - circuit voltage below threshold
U0415-68 (2A) Invalid data received from ABS control module - Algorithm based failure - event information
TCM-Transmission 6spd
U101B-87 (2E) Lost communication with GSM - multiple bus - Bus signal/message failure - missing a message
P279D-64 (2F) Four wheel drive range signal circuit - Algorithm based failure - signal plausibility failure
( on 03-10-2021 20:22:04 at 250993 km ) 1995 4.6 v8, green/tan (long gone)
Post #608118 3rd Oct 2021 7:36pm
coopss
Is this an important plug? Doesn’t look like it’s been used in a whil:
Post #608127 3rd Oct 2021 8:22pm
aids22
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Rimini Red
I would suspect a bad connection.
I had the same after disconnecting the battery to change the alternator.
The battery terminals appeared to be tight but as a last resort before buying a new battery I re-tightened them tighter than I would normally think necessary and have had no problem since. It did not make sense to me as they were already tight but it worked.
The fault codes are probably nothing to worry about. The voltage spike when you are trying to start will be causing all the ECU's to get confused.
Have a look at all the high current battery and earth connections to see if they are tight and not corroded.
Post #608136 3rd Oct 2021 9:56pm
GraemeS
Australia 2012 Range Rover Autobiography TDV8 Bournville
coopss wrote:
Is this an important plug? Doesn’t look like it’s been used in a while:
Mine has one of those hanging loose.
Post #608144 4th Oct 2021 4:17am
BenRK
On a RRS I had to use my diagnostic tool to tell the car it had a new battery and pair it up as that was throwing all sorts of faults. Once I done that everything was fine
Have you tried just clearing the codes and giving it a go?
I notice there's a message regarding the alternator there, has it ever been replaced?
Post #608155 4th Oct 2021 7:46am
dhallworth
When the starter motors on our car packed in we'd get a feint clunk from the starter. It wouldn't make the loud clunk as it tried to engage that you're getting.
Our dash didn't go out and come back on either.
Try running a jump lead from the engine to the negative terminal battery as if you've got a bad earth that should in theory bypass it.
Have you tried turning the engine over by hand? Might be worth trying to get a socket on the crank pulley from underneath and seeing if it'll spin.
Did this happen just after you'd switched it off?
Post #608159 4th Oct 2021 9:33am
coopss
@aids22 - thanks, will check all the connections for corrosion
@Benrk - I’ll do this reset later and see if it clears. Yep new alternator a couple years ago. Voltage up to over 14v when running
@dhallworth - When it happens again I’ll try this. Oddly started fine twice last last night so I don’t think it’s anything mechanical (thank god)
However - more good news - just discovered the coolant is low and there is a slight creaminess under the oil fill cap. Big Cry Big Cry The header tank is also under compression after running for a couple minutes. Is that normal? I dare not drive it now despite it starting
Post #608162 4th Oct 2021 10:01am
DrRob
That sounds like an oil-water emulsion which needs looking into more closely before running it for any length of time.
Post some pictures.
Has the oil cooler gaskets been done? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #608174 4th Oct 2021 12:26pm
coopss
Doubt it. Would the gaskets cause this issue, or the cooler itself? 1995 4.6 v8, green/tan (long gone)
Post #608175 4th Oct 2021 12:32pm
DrRob
Usually gaskets but best practice is to replace the cooler too as they can warp. My old one was and so new gaskets alone would not have fixed it. Usually shows as oil in the coolant. Emulsion in oil cap is sometimes a sign of head gasket. No point speculating without a proper diagnosis by a proper independent RR specialist etc Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #608176 4th Oct 2021 12:40pm
Page 1 of 3 123>
