![]() | Home > Technical (L322) > 4.4 tdv8 won’t start (not battery) |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7878 ![]() ![]() ![]() |
Sounds like the starter motor… seems to be something of a known issue.
coopss Member Since: 21 Apr 2018 Location: Hampshire Posts: 281 ![]() |
Hope not as it’s just had a brand new LR one! Second one in 14 months. Going down to read the codes shortly.. 1995 4.6 v8, green/tan (long gone)
Ah, probably not that either then….
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4326 ![]() ![]() ![]() |
Could be cable joins.
It just started. Odd. Here are the error codes
Is this an important plug? Doesn’t look like it’s been used in a whil:
aids22 Member Since: 10 Jun 2019 Location: Warrington Posts: 27 ![]() ![]() ![]() |
I would suspect a bad connection.
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2577 ![]() ![]() ![]() |
Mine has one of those hanging loose. |
BenRK Member Since: 19 May 2020 Location: County Durham Posts: 164 ![]() ![]() |
On a RRS I had to use my diagnostic tool to tell the car it had a new battery and pair it up as that was throwing all sorts of faults. Once I done that everything was fine
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3156 ![]() ![]() ![]() |
When the starter motors on our car packed in we'd get a feint clunk from the starter. It wouldn't make the loud clunk as it tried to engage that you're getting.
@aids22 - thanks, will check all the connections for corrosion
That sounds like an oil-water emulsion which needs looking into more closely before running it for any length of time.
Doubt it. Would the gaskets cause this issue, or the cooler itself? 1995 4.6 v8, green/tan (long gone)
Usually gaskets but best practice is to replace the cooler too as they can warp. My old one was and so new gaskets alone would not have fixed it. Usually shows as oil in the coolant. Emulsion in oil cap is sometimes a sign of head gasket. No point speculating without a proper diagnosis by a proper independent RR specialist etc Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
