![]() | Home > Technical (L405) > I'm now a Regeneration trainee nerd--lol |
Kot Member Since: 10 Mar 2021 Location: broadland Posts: 1276 ![]() ![]() |
No
luxmoggy Member Since: 19 Jun 2020 Location: Trier Posts: 471 ![]() ![]() ![]() |
OK, I have now seen it. I will ask for the "ECM DPF distance since last Regeneration" to be added to the "Range Rover, Range Rover 2017-2021". I can then start using this profile - which is more correct for my car.
CerebralThunder Member Since: 16 Mar 2022 Location: Midlands Posts: 22 ![]() ![]() |
I hope somebody can help,
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1607 ![]() ![]() ![]() |
You don’t actually HAVE to use any profile, -you can just choose “all sensors”, (assuming you know which sensors you wish to select). Once you add these to “Demo Mode” and customise the screen, your sensor selection & layout is saved for next time. |
Hmmm, I just changed mine to include “Miles since last regen” (as well as “Average distance between PF regens”)
Abacus405 Member Since: 01 Feb 2022 Location: West yorkshire Posts: 106 ![]() ![]() ![]() |
Your “miles since last regen” is in metres (so you’ve done 92km or around 55 miles), I can’t get it to display miles or km, just m 2017 (67) Vogue SE Corinthian Grey |
Mine is in KM for that sensor. SDV8 AB MY 2020
@Luxmoggy:
I think it is in the software
Open the PID select tab-sensor properties and you can select miles see screenshot
That’s the average distance between regens, not distance since last regen 2017 (67) Vogue SE Corinthian Grey |
Hi Kot, I’m using “all sensors” as its just not there under the profile for a 2017 V6, this is what I see:
Just seen the ECM pid doesn't allow units etc but there is an Average Distance between dpf Regens in the list which works.
Never mind all that, I just got excited |
