Home > Maintenance & Mods (L322) > L322 Lower Tailgate Straps - Lubrication prior to failure ! |
Pawl Member Since: 07 Nov 2017 Location: West Midlands Posts: 693 |
I had both lower tailgate straps break on me at the same time while lying partly in the boot (messing with a wiring issue. 2006 3.6 TDV8).
28th Aug 2021 9:33pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4306 |
Swapped out mine for new ones and coated the ends in grease.
6th Sep 2021 4:08pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35360 |
i'm sure the part numbers are here somewhere in this 2012 thread,
6th Sep 2021 4:10pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8257 |
Mt last one that I changed had rusted through in the middle, the ends looked OK but water had got inside the plastic sleeve and rusted out the wire...!!!
6th Sep 2021 5:06pm |
Rosco Member Since: 20 Jan 2012 Location: Beyond the wall. Posts: 2576 |
I need one, bit of advice from you chaps, all the ones I can find say 2002 - 2010, are these the same on 2011/2012 L322??
6th Sep 2021 5:07pm |
RR2B Member Since: 04 Aug 2020 Location: Rowlands Castle Posts: 251 |
Mine are newish but just noticed they do not rotate. Suspect the washer and spacer are incorrectly fitted, as the alignment doesn’t look right. 2011MY 4.4TDV8 Autobiography Baltic Blue
6th Sep 2021 5:22pm |
@rosco...all straps are the same except i seem to remember yours should have a dampner as well. ... - .- -.
6th Sep 2021 5:56pm |
Later ones have a damper Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
6th Sep 2021 6:15pm |
The strap on the right hand side is different if you have the damper mechanism fitted - due to the addition of the ball stud to the fastening bolt. This will apply to later cars and the many earlier cars that have had the damper mechanism added.
6th Sep 2021 7:12pm |
Thanks Pawl, just had a look and I do have a damper, its the left one I need, cheers again chaps |
6th Sep 2021 7:15pm |
Range Rover L322 Member Since: 03 Sep 2019 Location: South West Posts: 329 |
Great advice!... really appreciate the heads up. |
6th Sep 2021 11:23pm |
Is this correctly assempled? I’m thinking the spacers are on the wrong side? Neither end rotates and the alignment looks all wrong!
7th Sep 2021 10:44am |
Grayson Welly Member Since: 05 Sep 2021 Location: SW20 Posts: 95 |
Part number is Lr038048
7th Sep 2021 10:49am |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1194 |
Yes, as far as I know. Mine ( 2006 ) has been used as a seat for two people of at least 13 stone each for watching racing at Oulton Park - Never had any problems ( that was after fitting new straps, I hasten to add. ) |
7th Sep 2021 11:05am |
