Home > Maintenance & Mods (L322) > L322 Lower Tailgate Straps - Lubrication prior to failure !
Pawl
England 2007 Range Rover Vogue TDV8 Cairns Blue
I had both lower tailgate straps break on me at the same time while lying partly in the boot (messing with a wiring issue. 2006 3.6 TDV8).
Very annoying as the tailgate then dropped onto the bumper, putting 3 shallow dents in it (hopefully they’ll pull out ).
Removing the old straps & getting new replacements highlighted that the strap ends are supposed to rotate around each mounting bolt – something I’d never realised as they’re hidden under the rubber boots that cover the ends (& keep all the water in that causes them to rust & fail Sad ).
The old strap ends had obviously rusted solid at some point in the distant past – with the straps pointing downwards at both ends as they spend most of their lifetime with the tailgate shut.
What this meant was that when the tailgate was open the strap ends were “bent”, even though the rest of the cable was straight & taut, so when I added my weight to the tailgate there was incredible side loading on the cable attachments – which then failed as they’d got very weak due to rust.
If your strap pivots are still able to move, I’d suggest the boots should be lifted up & the pivots should be lubricated & the cable attachment point coated in grease or similar to reduce the likelihood of corrosion, seizing & potential failure.
I took the new cable assemblies apart & greased everything copiously prior to re-assembling & installing.
Hopefully they won’t fail again during my ownership of the car !
 Paul,
2001 Discovery 2 TD5, 211,000 miles & climbing
2006 FFRR TDV8 Vogue 151,000 miles & now sold
Member of Midland (Land) Rover Owners Club, www.mroc.co.uk
Post #605082 28th Aug 2021 9:33pm
Grayson Welly
I've noticed that one side (the nearside UK) of the hinge seems to have seized on both ends on ours. What are the part numbers for the replacement part? (I'll try copius amounts of Bilt Hamber Ferrosol first!)
Post #605744 6th Sep 2021 3:35pm
DrRob
Swapped out mine for new ones and coated the ends in grease.
Regularly inspect to ensure they are in good condition, rotate and greased Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #605746 6th Sep 2021 4:08pm
i'm sure the part numbers are here somewhere in this 2012 thread,
https://www.fullfatrr.com/forum/topic12664...ate+straps ... - .- -.
Post #605747 6th Sep 2021 4:10pm
Mt last one that I changed had rusted through in the middle, the ends looked OK but water had got inside the plastic sleeve and rusted out the wire...!!!
So if they look good on the ends, don't be fooled... Thumbs Up Pete
Post #605751 6th Sep 2021 5:06pm
Rosco
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
I need one, bit of advice from you chaps, all the ones I can find say 2002 - 2010, are these the same on 2011/2012 L322??
TIA Thumbs Up
Post #605752 6th Sep 2021 5:07pm
RR2B
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Baltic Blue
Mine are newish but just noticed they do not rotate. Suspect the washer and spacer are incorrectly fitted, as the alignment doesn’t look right. 2011MY 4.4TDV8 Autobiography Baltic Blue
TVR Griffith
Alfa Romeo Mito QV
Post #605754 6th Sep 2021 5:22pm
@rosco...all straps are the same except i seem to remember yours should have a dampner as well. ... - .- -.
Post #605761 6th Sep 2021 5:56pm
DrRob
Later ones have a damper Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #605765 6th Sep 2021 6:15pm
Pawl
The strap on the right hand side is different if you have the damper mechanism fitted - due to the addition of the ball stud to the fastening bolt. This will apply to later cars and the many earlier cars that have had the damper mechanism added.
If you have no damper, both straps are the same LR038051
If you have the damper, the LH strap is as above & the RH strap is LR038048 (with the ball stud) Paul,
Post #605772 6th Sep 2021 7:12pm
Rosco
Thanks Pawl, just had a look and I do have a damper, its the left one I need, cheers again chaps Bow down
Post #605773 6th Sep 2021 7:15pm
Range Rover L322
Great advice!... really appreciate the heads up.
Post #605801 6th Sep 2021 11:23pm
RR2B
Is this correctly assempled? I’m thinking the spacers are on the wrong side? Neither end rotates and the alignment looks all wrong!
Thanks in advance.
TVR Griffith
Alfa Romeo Mito QV
Post #605822 7th Sep 2021 10:44am
Grayson Welly
Part number is Lr038048
Out of interest, when in working order, is the lower tailgate designed to take weight?
Post #605825 7th Sep 2021 10:49am
Merchy
Yes, as far as I know. Mine ( 2006 ) has been used as a seat for two people of at least 13 stone each for watching racing at Oulton Park - Never had any problems ( that was after fitting new straps, I hasten to add. )
Post #605827 7th Sep 2021 11:05am
