Home > Maintenance & Mods (L322) > L322 Lower Tailgate Straps - Lubrication prior to failure !
Pawl
RR2B wrote:
Is this correctly assempled? I’m thinking the spacers are on the wrong side? Neither end rotates and the alignment looks all wrong!
Thanks in advance.
No, that's incorrect.
The support "washer" should be on the body side. Paul,
2006 FFRR TDV8 Vogue 151,000 miles & now sold
Post #605839 7th Sep 2021 3:51pm
ur20v
A Trap
Deleted
Post #605895 8th Sep 2021 8:54am
RR2B
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Baltic Blue
So I’ve refitted mine as follows: from tailgate out - fibre washer, spacer washer, rotating collar with black washers, bolt. However, if the bolt is more than hand tight it all binds and the collar no longer rotates. Something missing? 2011MY 4.4TDV8 Autobiography Baltic Blue
TVR Griffith
Alfa Romeo Mito QV
Post #605913 8th Sep 2021 11:11am
Pawl
RR2B : The spacer collar should have a shoulder that the rotating collar rotates around & protrudes above the rotating collar so the bolt head bottoms out on the spacer NOT the rotating collar.
if the spacer doesn't protrude enough, maybe the part isn't to spec. or has perhaps been crushed by overtightening.
Do both of the black plastic Washers sit flush with the rotating collar ?
They should be a "top hat" shape to act as a low friction surface between the internal diameter of the rotating collar & the outside diameter of the spacer and axially between the spacer & rotating collar & rotating collar and bolt head underside Paul,
Post #605967 8th Sep 2021 6:22pm
RR2B
I must be missing something - the bolt head tightens on the top hat washer which is not recessed. Once it is tightened there is no free rotation of the collar. Parts in order of assembly and assembled as per photos. This seemingly quick simple job is turning out to be very frustrating!
TVR Griffith
Alfa Romeo Mito QV
Post #606099 10th Sep 2021 4:41pm
Pawl
Are the straps genuine land rover?
If yes, I don't understand why they're different to mine - which are pretty loose fit.
It wouldn't surprise me if aftermarket manufacturers didn't understand how they should work & therefore don't copy the correct dimensions / features. Paul,
Post #606102 10th Sep 2021 5:53pm
RR2B
They were on the car when I bought it, I suspect after market as must be out of spec. I’ll live with the lack of rotation for the time being. 2011MY 4.4TDV8 Autobiography Baltic Blue
TVR Griffith
Alfa Romeo Mito QV
Post #606106 10th Sep 2021 6:03pm
