![]() | Home > Maintenance & Mods (L322) > L322 Lower Tailgate Straps - Lubrication prior to failure ! |
Pawl Member Since: 08 Nov 2017 Location: West Midlands Posts: 707 ![]() ![]() ![]() |
No, that's incorrect. The support "washer" should be on the body side. Paul, 2001 Discovery 2 TD5, 211,000 miles & climbing 2006 FFRR TDV8 Vogue 151,000 miles & now sold Member of Midland (Land) Rover Owners Club, www.mroc.co.uk |
ur20v Member Since: 19 Feb 2019 Location: None Posts: 634 ![]() ![]() |
Deleted |
RR2B : The spacer collar should have a shoulder that the rotating collar rotates around & protrudes above the rotating collar so the bolt head bottoms out on the spacer NOT the rotating collar.
RR2B Member Since: 04 Aug 2020 Location: Rowlands Castle Posts: 256 ![]() ![]() ![]() |
I must be missing something - the bolt head tightens on the top hat washer which is not recessed. Once it is tightened there is no free rotation of the collar. Parts in order of assembly and assembled as per photos. This seemingly quick simple job is turning out to be very frustrating!
Are the straps genuine land rover?
They were on the car when I bought it, I suspect after market as must be out of spec. I’ll live with the lack of rotation for the time being. 2011MY 4.4TDV8 Autobiography Baltic Blue
