![]() | Home > Technical (L322) > Towbar |
Bushy30 Member Since: 03 Jun 2018 Location: Powys Posts: 1099 ![]() ![]() ![]() |
Should be ! -- depends if the one you have is the original from LR -- ie Westfalia Current: 2011 FFRR Vogue SE 4.4 TDV8
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1210 ![]() ![]() ![]() |
I think you will find you will have tell the car if its 13 or 7 pin to stop the rear sensors going off? |
chris_read Member Since: 26 Feb 2012 Location: Louth, Lincolnshire Posts: 474 ![]() ![]() ![]() |
I thought the position of the exhaust hangers was different on the armature for the later models so it might be an idea to have a look underneath before you start removing it from the older car. 2017 Jaguar F Pace 25t Portfolio - still part of the JLR family 😀
It's only different on the final facelift Current: 2011 FFRR Vogue SE 4.4 TDV8
https://www.fullfatrr.com/forum/topic47780...t=armature
Bean19844 Member Since: 25 Oct 2020 Location: Essex Posts: 929 ![]() ![]() ![]() |
Cheers gents. Think I'll take it off and give it a try at least. If it fits happy days, if it don't it can go on ebay I guess seen as the car will likely go off to wbac unless someone on here wants it |
Towbar is the same (apart from hangers on the last facelift model) -- electrics changed Current: 2011 FFRR Vogue SE 4.4 TDV8
kooky_guy Member Since: 25 Nov 2011 Location: Sandhurst, Berkshire Posts: 386 ![]() ![]() ![]() |
The hanger issue is easily addressed. I cut them off a set of spare brackets I had (the ones you remove when you fit the armature anyway) and they can then be bolted in place when you fit the armature. 2010 4.4 TDV8 Vogue SE |
