Home > Technical (L322) > Towbar
Bean19844
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Bonatti Grey
Towbar
Ladies/gents/ whatever you identify as (equal rights etc)
So I placed an advert on here asking about a towbar for the 06 sc a while ago but it never really occurred too me I already have one on the 53 v8. The one I've already got is one that mounts too the chassis so it's not detachable. Anyone on here happen too know if this one would fit the 06sc. It was a plug and play one on the 53 plate so it knew when it was in trailer mode.
Cheers all
Post #604547 23rd Aug 2021 11:50am
Bushy30
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
Should be ! -- depends if the one you have is the original from LR -- ie Westfalia Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
2004 FFRR Vogue 4.4 V8 with LPG
1997 P38 4.0 SE with LPG
1997 P38 4.6 Vogue with LPG
Post #604565 23rd Aug 2021 1:50pm
Tinman
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
I think you will find you will have tell the car if its 13 or 7 pin to stop the rear sensors going off?
Post #604592 23rd Aug 2021 5:06pm
chris_read
England 2009 Range Rover Vogue TDV8 Stornoway Grey
I thought the position of the exhaust hangers was different on the armature for the later models so it might be an idea to have a look underneath before you start removing it from the older car. 2017 Jaguar F Pace 25t Portfolio - still part of the JLR family 😀
2009 3.6 V8 (MY2010) - my first ever diesel! - now also gone Sad
2004 4.4 V8 Petrol Vogue - now gone
Post #604594 23rd Aug 2021 6:02pm
Bushy30
It's only different on the final facelift Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
Post #604625 23rd Aug 2021 11:58pm
chris_read
https://www.fullfatrr.com/forum/topic47780...t=armature
This suggests that 2006 brought a change Thumbs Up 2017 Jaguar F Pace 25t Portfolio - still part of the JLR family 😀
Post #604634 24th Aug 2021 8:31am
Bean19844
Cheers gents. Think I'll take it off and give it a try at least. If it fits happy days, if it don't it can go on ebay I guess seen as the car will likely go off to wbac unless someone on here wants it
Post #604636 24th Aug 2021 9:18am
Bushy30
Towbar is the same (apart from hangers on the last facelift model) -- electrics changed Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
Post #604650 24th Aug 2021 12:14pm
kooky_guy
The hanger issue is easily addressed. I cut them off a set of spare brackets I had (the ones you remove when you fit the armature anyway) and they can then be bolted in place when you fit the armature. 2010 4.4 TDV8 Vogue SE
Post #605327 1st Sep 2021 3:37pm
