Home > General > What Did You Do In Your Full Fat Today
Page 343 of 382 <123 ... 342343344 ... 380381382>
JayGee
Did a guided suspension calibration with my IID tool. Got it to within a few mm but the light was fading so will give it another go today. Already looks like it’s sitting at a better ‘stance’ as the front was 10mm too high. 2012 TDV8 Vogue (L322)
Post #612612 14th Nov 2021 12:33pm
appj62
England 2006 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
After whacking my head a couple of times, recently, have changed out upper tailgate struts. Did the bonnet ones over a year ago. Previous cars:
S-Max 2007-2013 (only diesel I've had, good car but expensive when diesely bits go wrong, so what's the point?)
Galaxy 2001-2007
Mondeo Estate 1997-2001
Sierra Estate 1993-1997
Uno Turbo 1987 -1993
Fiesta 1984 - 1987
Fiat 127 1982 - 1984
Post #612630 14th Nov 2021 3:21pm
Bean19844
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Bonatti Grey
Started to rectify the brake guards on the old v8 so it can get motd. All was going well till next door come and found me and they was looking somewhat sheepish.
Yea hi we are your neighbours and we are really sorry but
Joyful so now trying to source a new door
Post #612640 14th Nov 2021 4:36pm
Ffrr-lover
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
4 new tyres for my fatty!
Jumped up from 285/35R22’s to 285/45R22’s! Only driven a few congested miles in them so cannot say what difference it makes, but will know for sure tomorrow!!! Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
Past rides:
2014 Audi Q7 3.0d (good riddance)
2010 L322 Autobiography 5.0 Supercharged
2011 L320 HSE 3.0 sdv6
2014 Jaguar XF-RS 5.0 supercharged
2007 BMW 535D
2005 Mini Cooper S
https://www.fullfatrr.com/forum/topic59478.html
Post #612836 16th Nov 2021 9:06pm
Barmybrummie
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Santorini Black
Gave the beast yet another coat of polish today while I've got a rare few days off. This time I used X1 PTFE polish, which I find to be excellent. Such a deep gleaming shine.
Post #613205 19th Nov 2021 10:48pm
Barmybrummie
Took her out in the snow today for the first time since I've had her. There's quite a steep hump back bridge by me and had to wait for 3 other cars to be pushed up it, while mine just breezed straight up and over no problem.
Post #614033 28th Nov 2021 5:19pm
RRover
2012 Range Rover Westminster TDV8 Causeway Grey
Took westy on longer trip today for second, longer outing (only 40-miles round trip) to see if three fault codes still remain cleared after having them wiped by my new mobile engineer using a LAUNCH PRO 129X - and no codes popped up and nor any dings whatsoever!!! Very Happy Big Cry Very Happy Thumbs Up
Good feeling after living with three codes and dings for three years solid now: hooray!!! Wink
Rye was really Christmas-like today - had cream teas until feeling nauseous, and then carrot cake was washed down with cappuccino - feel really sick now.
Checked oil levels just after returning and all-AOK: dead on MAX...
Will check coolant level tomorrow...
New buddy and hero mobile engineer returning Monday to check on the wee oil burning smell if westy is pushed - oil-cooler already done, and a few other seals and washers or o-rings down there, but he has some ideas that don't sound pricey. Also he will check on any corrosion on chassis, and do a general under-car check.
New starter motor fitted few months back now working a treat - no more clicky-clicky at stop/start...
Post #614484 2nd Dec 2021 7:02pm
Bloke
Scotland 2009 Range Rover Vogue TDV8 Buckingham Blue
New tow bar guard fitted + new gas struts front and rear. Bonnet was the worst, couldn't trust it to stay up. Not the originals but Stabilus on the front, rears were non branded. £40 for a replacement set from PowerfulUK seemed a good deal.
Oil service carried out yesterday, keeping it on a 6 month changes, doing the work myself means I'm paying about the same as an annual change at an indy. Full engine service kit inc 10L 5W/30 was £140 from Advance Factors. Will be changing the fuel filter, but doubt the pollen or air filter need changing, so those will be saved for future need.
Also sprayed on some Lanoguard to the subframes and chassis rails. Bit like painting the Forth Bridge me thinks...
Post #614716 4th Dec 2021 4:58pm
Bl4ckD0g
Netherlands 2010 Range Rover Autobiography 5.0 SC V8 Santorini Black
Washed it and put my little winter wheels and tyres on it.
Post #614728 4th Dec 2021 5:57pm
Baltic Blue
I have just done a forced regen ( 390 miles since last one) to reduce the DPF soot level down from 17g to 1.98g.
Bow down Thanks again to Pat @ GAP.
Post #614851 5th Dec 2021 3:26pm
Jayk69
New AC compressor on mine today so the HAVAC works properly in Auto i can set the temp and forget about it instead of freezing my but off and having to turn off the AC. Thumbs Up 2012 Vogue 4.4 TDV8 - Current
2014 Navara V6 - Gone
2004 Vogue TD6 - Gone
Grand Cherokee - Gone
Discovery V8 (LPG) - Gone
Discovery TD5 - Gone
Post #615255 8th Dec 2021 9:20am
Dolphinboy
took my 2011 which I've had for 4 years for its MOT. PASS and NO advisories again. Did have to have a new front left lower arm replaced after hitting a BIG pothole.
Bought with 83,000. Now on 112,000. Not bad for an Ebay car!!
Post #615532 9th Dec 2021 7:01pm
oggy
United Kingdom 2007 Range Rover Vogue SE 4.2 SC V8 Java Black
mot pass
my first mot with the 4,2 s/c 2007 to day full pass no advisories i did spend 5 months on it when i got it back in feb 21 the chap who moted it said he had never seen such a clean l322 so i must have done my job right when i got it new vehicle purchase
2007 supercharged 4.2 java black .sand leather vogue se trim
previous cars .
range rover classic 200 tdi
discovery 1 200 tdi
freelander 2 2008 hse
discovery 1 300 tdi
p38 4.0 ltr man r380 ex royal support vehicle on v5c
discovery td5 man off roader
Post #615544 9th Dec 2021 8:20pm
Weegie
Actually yesterday and the day before drove from Home (SW France) to Dieppe. Car was faultless. Now in UK where, to my chagrin, we are now relocated.
Family requirements dictated a return to UK. Next thing is house hunting in Sussex. Crying or Very sad John
GAP iiD BT-Sold
Post #615630 10th Dec 2021 11:11am
just a reminder to members that this is a 'one' post thread so please dont discuss or reply to posts as this spoils the thread..thanks. ... - .- -.
Post #615646 10th Dec 2021 12:06pm
