Home > General > What Did You Do In Your Full Fat Today
Page 329 of 379 <123 ... 328329330 ... 377378379>
aterkut
Turkey 2008 Range Rover HSE TDV8 Java Black
was just thinking of alternator replacement for my TDV8 but we saw a oil leak from rocker cover so decided to strip some more for more room Smile
as a result;
alternator replacement with new
alternator belt replacement with new
belt tensioners replacement with new
rocker cover gaskets replacement with new
injectors maintenance
turbos maintenance
Post #585271 25th Feb 2021 7:48pm
vs322
Greece 2004 Range Rover HSE 4.4 V8 Java Black
Rear wiper had been acting up for quite some time until it finally stopped completely.
Turns out almost everything was seized inside. Cost me half a can of penetrating oil, a whole afternoon and my...manicure to take it all apart.
The white gear was an absolute nightmare to remove. As I didn't mark the positioning, it also took me a lot of trial and error to fit everything back together. But in the state it all was, no markings could survive. Fortunately no replacement parts were needed.
All sorted now...Fullfat wagging it's tail happily...
Post #585498 27th Feb 2021 5:58am
matlandy
United Kingdom 2004 Range Rover Vogue Td6 Java Black
Sorted out the fluctuating temperature gauge by changing the EGR thermostat.
Post #585512 27th Feb 2021 9:27am
matlandy
Also fitted my summer wheels
Post #585557 27th Feb 2021 3:57pm
Bean19844
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Bonatti Grey
Mines all loaded for the weekly tip run tomorrow morning, then off too the trailer park to see if I can get the stupid led lights to work properly on the car trailer
Post #585594 27th Feb 2021 8:43pm
Bloke
Scotland 2009 Range Rover Vogue TDV8 Buckingham Blue
Thought I'd check the MOT status as it is due in March ISTR? Feck me, next Thursday, March 4th all day. Don't panic. Shocked
Needs brakes mainly. Front rotors N pads. Pads were okay, rotors were shagged though, so they got replaced with MTEC grooved N drilled rotors and new matching pads from stock, not shown. They seem alright and should last as long as any other brand 3/5 years. Total cost was £110 delivered to my door, which is astounding value for money. £55 per side. I will update once a few hundred miles been covered as still very much new and bedding in. https://www.mtecbrakes.com/
TDV8 Brembo brakes really were a MUCH needed UPGRADE to those Lucas Very Happy fitted to the TD6, which can only be described at best as just about, adequate with good planning and early deployment. Whistle
Brembo caught me out in the tool dept. Didn't have a drift in stock, man enough, to drift out the brake pad securing pins. Screwfix did though. £8 for a set. So the old truck now stops almost as well as it goes which is kinda handy. Razz
Rear shocks replacement are next on the list.... Thumbs Up
Post #585709 28th Feb 2021 6:44pm
bigbo
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
Changed the power steering fluid, using the syringe out from the reservoir and top up with fresh method. I used about 2.5L of fluid but now it looks quite clean.
But to be sure I will repeat in a few months. Range Rover 4.2 Supercharged 2006
Ford Focus EcoBoost 1.5 2017
MG TF 2003
Previous Cars of note
Land Rover Discovery 2
Jaguar Mk2 3.8 - Company car
MG Midget 1974 - Concours
Post #585745 1st Mar 2021 12:45am
jim4244
England 2005 Range Rover Vogue Td6 Zambezi Silver
Treated her chassis and all cavities for rust and corrosion
Jim
Post #585752 1st Mar 2021 6:55am
4434Morrison
United Kingdom 2012 Range Rover Vogue SE TDV8 Santorini Black
Passed it's MOT today, no advisories.
Plus full service.
Preventative maintenance pays. 2012 4.4 TDV8 Vogue SE Current
2015 E220 with AMG Sport Pack - Currently driven by my son
2010 3.6 TDV8 Vogue - Written off by my son
Post #585918 2nd Mar 2021 11:13am
Bloke
Rear shocks done. Was really straight forward job. Bottom mounting nut & bolt came off no bother on both sides, access to top of the shock was easy enough too from inside the car. Most difficult part of working on Reggie is getting the wheels back on they're so bloody big and heavy. All four wheels studs now torqued upto 140nm, as they've all been off in the last few days. Ready for the MOT on Sat morning. Then oil service will be due again as on 6 monthly changes.
Post #585976 2nd Mar 2021 5:43pm
Jayk69
Gearbox service today and another coolant flush (Oil contaminated from leaky oil cooler!)
just diffs and transfer case to do next 2012 Vogue 4.4 TDV8 - Current
2014 Navara V6 - Gone
2004 Vogue TD6 - Gone
Grand Cherokee - Gone
Discovery V8 (LPG) - Gone
Discovery TD5 - Gone
Post #586067 3rd Mar 2021 5:22pm
Doonhamer
United Kingdom 2011 Range Rover Vogue 4.4 V8 Santorini Black
Bonnet stays and reversing lights
Just been out and changed both bonnet props (old ones were getting a bit weak) and both reversing lights (offside was cracked at the mounting screw hole, both a bit manly). Won’t have to prop the bonnet up with a broom shank now, and looking forward to seeing what difference having new lamps makes. L322 TDV8 4.4 - current
L322 TD6 - sold
Disco 2 TD5 - sold
Suzuki Grand Vitara XL7 - sold
Mitsubishi Pajero 2.8 - part ex'd
Hyundai Santa Fe 2.0 td - sold
Mitsubishi Pajero 2.8 - sold
Post #586069 3rd Mar 2021 5:31pm
Bl4ckD0g
Netherlands 2010 Range Rover Autobiography 5.0 SC V8 Santorini Black
I collected mine from the garage, surprised them with how much I was able to pay with the tap of my phone Laughing And somehow I was pleasantly surprise how 'small' this large bill was spanning three pages of A4 with lines of labour and parts Shocked Confused Very Happy
But my gosh it runs sweet, silent and revs like with the slightest touch. I drove there in my wife's BMW M2 Competition, so a slightly different beast being twin turbo and straight six. But so so nice to be back in my big black beast.
* Full service with all filters, plugs, 0w20 oil etc
* Refurbed the supercharger with the repair kit, all new gaskets and bolts as well.
* New bolts along the chain guides as well. No need to replace it at all.
* All new hoses, cleaned the oil cooler and new gaskets.
* New gaskets, seals and hoses towards the waterpump.
* New CV gaitors
* New rear calipers, discs, pads, hoses, and they kept them black! Well done...
* And they fixed the peeling key which was a nice little touch
She is running so smooth, sweets, a consistent shove where I thought it is good but now I can feel the difference compared to having had play in it. My gosh what a machine, it is like I am experiencing it all over again...
Anyway, now the fun games can start. Next I think she deserves some different pulleys and a little remap Twisted Evil
Post #586277 4th Mar 2021 6:01pm
appj62
England 2006 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
Took mine out for a run after 2 weeks of sitting doing nothing (haven't had the heart to SORN it yet). Some spirited😉 driving was involved and I loved it! Previous cars:
S-Max 2007-2013 (only diesel I've had, good car but expensive when diesely bits go wrong, so what's the point?)
Galaxy 2001-2007
Mondeo Estate 1997-2001
Sierra Estate 1993-1997
Uno Turbo 1987 -1993
Fiesta 1984 - 1987
Fiat 127 1982 - 1984
Post #586329 4th Mar 2021 10:41pm
IGP
United Kingdom 2013 Range Rover Vogue SE SDV8 Siberian Silver
Took it for it's MOT. Passed with no advisories. Also had a full service whilst it was there.
I do hate it when MOT testers put on needless advisories. My D3 had advisories for being "lightly corroded" underneath. It's a 16 year old car FFS it's bound to have light corrosion. If the corrosion had been serious then fine mention it.
Ivan 2013 Vogue SE SDV8
2013 Freelander 2 SD4 HSE Luxury
Post #586346 5th Mar 2021 9:00am
