![]() | Home > General > What Did You Do In Your Full Fat Today |
vs322 Member Since: 08 Apr 2020 Location: Athens Posts: 594 ![]() ![]() ![]() |
Rear wiper had been acting up for quite some time until it finally stopped completely.
matlandy Member Since: 06 Aug 2016 Location: Crawley Posts: 134 ![]() ![]() ![]() |
Sorted out the fluctuating temperature gauge by changing the EGR thermostat. |
Also fitted my summer wheels
Bean19844 Member Since: 25 Oct 2020 Location: Essex Posts: 929 ![]() ![]() ![]() |
Mines all loaded for the weekly tip run tomorrow morning, then off too the trailer park to see if I can get the stupid led lights to work properly on the car trailer |
Bloke Member Since: 13 May 2019 Location: On the road to Oban Posts: 120 ![]() ![]() ![]() |
bigbo Member Since: 07 Jul 2014 Location: Derbyshire Posts: 595 ![]() ![]() ![]() |
Changed the power steering fluid, using the syringe out from the reservoir and top up with fresh method. I used about 2.5L of fluid but now it looks quite clean.
jim4244 Member Since: 31 May 2012 Location: UK Posts: 853 ![]() ![]() ![]() |
Treated her chassis and all cavities for rust and corrosion
4434Morrison Member Since: 02 Mar 2020 Location: Folkestone Posts: 185 ![]() ![]() ![]() |
Passed it's MOT today, no advisories.
Rear shocks done. Was really straight forward job. Bottom mounting nut & bolt came off no bother on both sides, access to top of the shock was easy enough too from inside the car. Most difficult part of working on Reggie is getting the wheels back on they're so bloody big and heavy. All four wheels studs now torqued upto 140nm, as they've all been off in the last few days. Ready for the MOT on Sat morning. Then oil service will be due again as on 6 monthly changes.
Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601 ![]() ![]() ![]() |
Gearbox service today and another coolant flush (Oil contaminated from leaky oil cooler!)
Doonhamer Member Since: 07 Jul 2017 Location: Thatcham, Berkshire Posts: 209 ![]() ![]() ![]() |
Just been out and changed both bonnet props (old ones were getting a bit weak) and both reversing lights (offside was cracked at the mounting screw hole, both a bit manly). Won’t have to prop the bonnet up with a broom shank now, and looking forward to seeing what difference having new lamps makes. L322 TDV8 4.4 - current
Bl4ckD0g Member Since: 16 Feb 2020 Location: 127.0.0.1 Posts: 1322 ![]() ![]() ![]() |
I collected mine from the garage, surprised them with how much I was able to pay with the tap of my phone |
appj62 Member Since: 07 Aug 2013 Location: Cheshire Posts: 424 ![]() ![]() ![]() |
Took mine out for a run after 2 weeks of sitting doing nothing (haven't had the heart to SORN it yet). Some spirited😉 driving was involved and I loved it! Previous cars:
IGP Member Since: 09 Jul 2020 Location: Malvern Posts: 294 ![]() ![]() ![]() |
Took it for it's MOT. Passed with no advisories. Also had a full service whilst it was there.
