Home > General > What Did You Do In Your Full Fat Today
Page 321 of 379 <123 ... 320321322 ... 377378379>
b348xyx
All Parts Delphi And Genuine LR. All new replacement bolts, and nuts.
1, Replaced Front Brembo Brakes Discs (New Replacement Discs, Brake Disc Set Screw’s)
2, Replaced Front Brake Pads & Bleed Brakes (With New Brembo Pads, Pin’s, Clip’s, Calliper Bolts)
3, Replaced Front Track Arms (With New Bolts And Washers)
4, Replaced Front Lower Control Arms (With New Bolts and Washers)
5, Replaced Front Ball Joints (With New Screw/bolts)
6, Replaced Tie Rod Ends & Inner’s as most likely be stuck solid
7, Replaced “Drivers Side” Anti Roll Bar Link
9, 4 Wheel Tracking Wheel Alignment due to above being replaced
10, Mot Car
£560 in parts, £506 Labour.. Tracking/MOT and some Misc Bits and brake lines.. £220ish...
Nearly £1300 Total... Got to love range rovers..
Only bit most likely did not need was inner tie rods but labour trying to get old ones unstuck vs new ones.. so on..
Olds parts show they were indeed in need of replacing... 3 blown ball joints.. other ones very worn.. rubber bushing were really crap condition and one bush metal casting had blown out..
Strange how front car was in need all this but the rear bushing and so on all seems good at the moment. 2003 Range Rover 4.4 Litre V8 - Adriatic blue
2003 Range Rover 4.4 Litre V8 -Maintenance History Click Here = http://www.fullfatrr.com/forum/topic39687.html
Post #569182 7th Oct 2020 10:20pm
ebajema
Had the rear suspension bushings done yesterday.
The oil and filter change was a bit of a f up and today I had to go back to let them drain 2 liters of overfill out.
But today I FINALLY got my Kiwi plates and it is now fully road legal here (including over the top underbody protection).
So this weekend I'm going on the first proper road trip, first to the Whangamomona hotel and then Mt Damper Falls. Little 4 hr. round trip with some proper gravel roads.
Happy camper here!!! MY 2010 5.0 SC Galway green and sand interior!!
Post #569278 9th Oct 2020 6:11am
Got to play with my new toy -
Expensive but very impressed Thumbs Up
Set the pressure, screw onto the valve, press the button & away it goes until done. It's quick & fairly quiet. I hadn't realised how much of a faff my old one was, needing a cable Laughing .
Post #569458 11th Oct 2020 6:54am
vs322
Greece 2004 Range Rover HSE 4.4 V8 Java Black
Just drove it. 250 kilometers yesterday and another 200 today.
From tarmac to mud, through harvested wheat fields and olive fields all the way up the hills rock crawling. Had an absolute blast!
Post #569509 11th Oct 2020 3:38pm
RRDunc
England 2012 Range Rover Autobiography TDV8 Santorini Black
Washed it.
Dunc.
 The life you have is the only one you'll get; make the most of it.
2012 4.4 TDV8 L322 Autobiography
2003 TD5 Oslo Blue D2 ES Premium Auto (with mods!)
Post #569519 11th Oct 2020 4:41pm
t5pete
Removed side steps
Fitted dog guard
Washed
Post #569541 11th Oct 2020 7:29pm
Fox889
Yesterday gave the old girl a good wash, drive a few miles to shake off any water droplets hiding somewhere, then used the new car cover to protect her against leaves, bits of sap & general crud. It's only a cheapie but seems ok.
 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
Alfa Romeo Giulietta
Austin A40 Farina MK2
1975 Morris Marina 1.8TC
1973 Honda CB250 K4
Post #569581 12th Oct 2020 7:58am
had a trip to Cotswold Airport to see the now un-used BA 747's..
Post #569640 12th Oct 2020 3:29pm
ebajema
Thinking of getting your own private 747 Stan?? No more having to sit in cattle class????[/quote] MY 2010 5.0 SC Galway green and sand interior!!
Post #569787 14th Oct 2020 8:00am
ebajema
First drive Whangamomona Hotel Forgotten World Highway
On Saturday we took the RR, now fully registered in NZ, to Whangamomona and along the Forgotten World Highway. Part of the FWH is gravel road so she got a bit dusty!!!!! She is so nice to drive on these twisty roads and on the gravel (and bad surfaces). I think we're going to enjoy driving here even more!!
Post #569789 14th Oct 2020 8:13am
Hope you had your mac and plane spotters hat on Stan Whistle Whistle Whistle
Post #569790 14th Oct 2020 8:14am
Red Hot one
United Kingdom 2009 Range Rover Vogue TDV8 Stornoway Grey
Working vehicle
Put the old beast to work, tows effortlessly, just don't look at the instant fuel consumption.
Post #570238 18th Oct 2020 5:33pm
bigbo
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
Installed a complete interior LED kit (from Amazon kit recommended on this forum)
Only issues the passenger "knee" light is very nearly impossible to do, at least for my hands, I removed the cup holder which helped.
The Approach/under mirror do not work.
And I have two lamps left over.
David Range Rover 4.2 Supercharged 2006
Ford Focus EcoBoost 1.5 2017
MG TF 2003
Previous Cars of note
Land Rover Discovery 2
Jaguar Mk2 3.8 - Company car
MG Midget 1974 - Concours
Post #570271 19th Oct 2020 12:53am
xjsracer44
United Kingdom 2007 Range Rover Vogue SE Supercharged Java Black
Had one front calliper replaced - yes one!
I noticed a weep from the drivers side calliper so ordered a pair, however, they only had one side in stock, thankfully the one I needed, so I'm driving around with one new calliper until the other one arrives, as it's on back order.
Post #570325 19th Oct 2020 3:52pm
DaveK
United Kingdom 2013 Range Rover Vogue TDV6 Corris Grey
On the ramp, oil and filter changed ( and I undo the difficult nut behind the crossmember to drain ! ) . Do this every 8 thous miles.
Post #571347 30th Oct 2020 7:46pm
