Home > General > What Did You Do In Your Full Fat Today
Page 242 of 377 <123 ... 241242243 ... 375376377>
NobbyC
United Kingdom 2005 Range Rover Vogue 4.4 V8 Buckingham Blue
Thumbs Up Looks beautiful - love the colour too. If your ever bored you can come here anytime and do mine Whistle
Post #431668 19th Mar 2017 8:58pm
drove my nice shiney clean westie in the rain, not so clean now.. Crying or Very sad ... - .- -.
Post #431669 19th Mar 2017 9:09pm
Dieterf
South Africa 2007 Range Rover Supercharged 4.2 SC V8 Java Black
Water restrictions here (Cape Town SA) so ban on car washing unless at a commercial drive thru with mechanical washer and using recycled water!
reckon it'll do more damage than good.
SO dirty she stays Big Cry
Post #431727 20th Mar 2017 9:44am
b348xyx
Thanks guys was happy with the results.
although its raining today still looks good with the water beading down the car Smile 2003 Range Rover 4.4 Litre V8 - Adriatic blue
2003 Range Rover 4.4 Litre V8 -Maintenance History Click Here = http://www.fullfatrr.com/forum/topic39687.html
Post #431731 20th Mar 2017 10:15am
mpirie
Stripped and cleaned the oil cooler and replaced both gaskets.
Spent an hour or so fishing the oil out of the coolant........time will tell if i've been successful and if not will ask Dan if he'll swap my first-born for a replacement oil cooler Thumbs Up
Come to think on it; I was more nervous starting the car up afterwards than I was when the first-born arrived Rolling with laughter
Post #431732 20th Mar 2017 10:17am
Yesterday, collected our Topper and windsurfer, along with masts and rigging for two other boats, and folding launching trolley, along with two passengers. Booms and split masts fitted nicely diagonally from the dashboard to the boot area! Took longer to tie everything on than it did to drive home!
Post #431855 20th Mar 2017 10:14pm
verydisco
Drove 6 hours, filled up, not even tired! l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
Current
Previous:
Post #432049 22nd Mar 2017 10:49am
rar110
I almost always use chemicalguys Eco wash quick detailer to clean my car, with spray bottle and 2 or 3 microfibre towels. The wheels is the last thing I do as they get dirtiest.
It's great for water restrictions as no hose or bucket used. ______________________________
Post #432143 22nd Mar 2017 8:42pm
daveenty
Managed something technical today which I've been putting off because of the bad weather. Smile
It's not really that technical to some of the stuff you guys do, but it was bugging me and therefore needed sorting out.
A post external trim panels. They never really lined up at the top properly and, having had a good poke around, it became pretty obvious why. The little internal clips were just not gripping, causing the trim to pull away from the screen so, after removing one to find out exactly what I needed (and being gutted that I didn't have anything to fit), I made the trip to my local dealers.
£32.83 lighter, and with my little plastic bag full of clips, I came back home and refitted everything. After a lot of cleaning under the trim. I bought both the white internal clips and the black push pins. I have some plastic rivets which "may" have fitted, though for the price I thought I may as well just go with the genuine ones.
The trims now look as they should be and there's no gap anymore, so all being well they will last a good while. I never really noticed much wind noise before, which is apparently a common sign of them failing, though I don't do a great deal of motorway stuff anyway. Hopefully there won't be any now... Dave
2010 5.0 Autobiography
Post #432237 23rd Mar 2017 12:29pm
rvbush
United Kingdom 2011 Range Rover Vogue TDV8 Stornoway Grey
Fitted new rear brake pads and sensor because check control light came on for 'check pads' Quick look around showed it was the rears that were most worn.
Except that wasn't what was causing the check control warning to come on! Damn pads were only just over 50% worn, turned out the front sensor cable had managed to get itself unclipped and had worked into a position where the cable rubbed on the inside of the road wheel, causing it to short and throw the warning. So I bought and fitted pads that didn't need doing and I still have have the warning. New sensor ordered.
Damn cars Evil or Very Mad Drives:
2010 FFRR TdV8 Vogue - Stornoway Grey
2010 FFRR TdV8 Vogue SE - Zermatt Silver
1998 BMW E36 M3 GTII
Post #432716 26th Mar 2017 2:31pm
Baltic Blue
Put them back in and save the new ones ? G reg 2.5VM Vogue Portofino red 1991- 1999
Post #432724 26th Mar 2017 3:10pm
Baltic Blue
Probably like half the members on here, washed and polished whilst enjoying the sunshine.
Taking for a run to Blackpool tomorrow when it will be quieter. G reg 2.5VM Vogue Portofino red 1991- 1999
Post #432725 26th Mar 2017 3:12pm
rvbush
I could, but at least it's got new pads on now. When I saw the pads weren't worn out (to be fair they were actually about 60 - 70% worn when I looked again, not just over 50%) I still did the job in case the sensor wire at the rear was faulty. It wasn't, it was the front. Never mind. Drives:
Post #432727 26th Mar 2017 3:20pm
today i looked out of the window at the car i polished yesterday. Very Happy
checked the oil, water, tyre pressures, cleaned the glass, gliptoned the seats, dusted the dash, emptied some tat out of the boot.
cant think of anything else to do with it, and cant go for a drive cos i had a couple or four beers at lunch Big Cry
ooooo, SCREENWASH. something else to do! There is nothing that can't be fixed with a hammer😜😜
Post #432743 26th Mar 2017 4:31pm
Webbie
Made the mistake of pressure washing my exhaust silencer as it look a bit muddy. There is some paint left on it Sad
Post #432752 26th Mar 2017 5:21pm
