Home > General > What Did You Do In Your Full Fat Today
Page 105 of 376 <123 ... 104105106 ... 374375376>
Im guessing you have a connector somewhere that isn't sealed tight and could do with a blob of grease around it to keep the stuff at bay. The white spray on stuff is good Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #156479 10th Dec 2012 3:19pm
Nothing, it's still tucked up in the garage for over 5 weeks now although I was tempted to take it out today as I had to collect a new door latch for my daughters car, then I spied SWMBO's Mini and took it instead Laughing Laughing
Post #157424 14th Dec 2012 3:03pm
Hope its on a trickle charger lol FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #157435 14th Dec 2012 3:49pm
No need Will, I have zero drain from the battery when it's garaged Whistle Thumbs Up Thumbs Up
Post #157493 14th Dec 2012 6:44pm
Andy3681
United Kingdom 2005 Range Rover Vogue Td6 Cairns Blue
Last week used it to collect ultimate man toy a ride on mower, then had no heating on the coldest week of the year as the FSR. Packed up. I did the decent thing and let the wife have the car this week so she was 'safe' in the ice.
Then spent hour wrestling with FSR yesterday now got double jointed wrist and bad back.
Thumbs Up Mine was a blue one! Smile
Post #157721 16th Dec 2012 8:52am
TheAllSeeingPie
United Kingdom 2007 Range Rover Supercharged Supercharged Java Black
Yesterday morning: got shunted in traffic which dislodged a parking sensor and put some paint on my towing eye. He appeared to lose a headlight.
Yesterday evening: removed rear bumper and repaired parking sensor by torchlight.
07 Supercharged - Still breaking her in!
Boot soundproofing part 1 - http://www.fullfatrr.com/forum/topic15612.html
Custom exhaust - http://www.fullfatrr.com/forum/topic15296.html
18" wheels for Brembo equipped cars - http://www.fullfatrr.com/forum/topic15052.html
Post #158453 19th Dec 2012 9:42am
Off to buy a nice Supercharged 2012 Conversion for personal use - will post pics later Thumbs Up
Post #158677 20th Dec 2012 10:01am
Left it at home, had to use the wifes car. Big Cry
Used RR the day before with no problem, went to start it today not even a click when I turned the key, voltage dived from 12.6V to 8V.
Hopefully just the battery has failed.
I'll check tomorrow if the rain stops and look for a replacement. Censored
Post #158807 20th Dec 2012 4:59pm
salb
United Kingdom 2007 Range Rover Vogue SE Supercharged Santorini Black
spent all day with my new TOOL Rolling with laughter Rolling with laughter
IID TOOL LOL.
what a day, who said it was easy managed to shut the whole car down and thought
id killed it.
but its alive with a few subtle changes, what a TOOL,
VIRTUALLY ORGASMIC LOL.
sal
special mention to stan for his patience and contribution !! RANGE ROVER OVERFINCHED 4.2 S/C
FRONT BUMPER O/F
REAR BUMPER. O/F
BOOT SPOILER O/F
22" ALLOYS. O/F
STAINLESS STEEL EXHAUST O/F
CARBON FIBRE WING MIRRORS & A PILLARS & CENTRE CONSOLE
Post #158815 20th Dec 2012 5:26pm
New bonnet catch and cables arrived so I braved the elements of the garage and made a start changing them over. I had ordered 2 catches but for some reason Dan only sent one, so I decided to try and repair the better of the two already fitted.
The catch is made of plastic and metal, held together with 2 bent over tabs and a rivet so I unbent the tabs and took the Dremel to the rivet hoping I could reuse it. Once I had opened the catch up the problem was easily seen, rust on the top plate and crap inside the plastic causing it to jam. I wire brushed the top and bottom plates and gave them a coat of paint, cleaned out the plastic parts and reassembled with a coating of grease, sadly the rivet was not able to be reused so I used a round head bolt and a lock-nut instead and hammered the bottom of the bolt once assembled to ensure it would not work loose. You have to make sure the top of the bolt is lower than the metal plate or it will foul on the slam-panel. When I finished the latches I started changing the 3 cables, I must admit that the two cables under the bonnet were in reasonably good condition but at £6 & £7 each I thought I would change them whilst I was at it. The cable from the inside (common for breaking) could have lasted for a while yet as there were no broken strands, but it was rather bent and distorted so I am glad I changed it when I did. The hardest part of changing this cable was getting the old grommet out.
If you do plan changing the inside cable tie/tape a piece of wire to the old cable in the engine compartment and pull through to the cab, then put the wire onto the new cable and gently pull it back up into the engine compartment.
Just need to take it out for a drive now Laughing Laughing
Post #159239 22nd Dec 2012 5:24pm
Tieing some string on is for girls Wink be a man and do it without John!!
Today mine went last minute Xmas shopping with me. Lots of big puddles and empty flooded inside lanes made life so much easier and anothe jaunt out tomorrow should loosen the muck that's been on for the last month ready for a good wash.
Also had to take a toolset out of it so I could lift a manhole cover as unblock a friends sewer Sad still stink now but even 10m's of rods didn't clear much and god it must have been backed up for yonks!!! Sad FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #159452 22nd Dec 2012 11:57pm
Went out in mine for the first time in over 7 weeks and it's running like a dream... Mr. Green Mr. Green Mr. Green
Post #159805 24th Dec 2012 12:34pm
mrblonde
United Kingdom 2003 Range Rover Vogue Td6 Adriatic Blue
50 miles delivering presents and sitting in bit of town traffic to get to the shops. Cheeky smile from hot blonde in a gorgeous black autobiography made it less painful too
Post #159919 24th Dec 2012 5:49pm
mrblonde wrote:
...hot blonde in a gorgeous black autobiography
Whistle Whistle Whistle
Post #159925 24th Dec 2012 6:00pm
mrblonde
Think that was her! So the panting thing she did, didn't mean she wanted me?? Gutted.com
Post #159927 24th Dec 2012 6:03pm
