![]() | Home > Maintenance & Mods (L322) > Turbo Failure 3.6 TDV8 |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8389 ![]() ![]() ![]() |
When turbos fail it's usually white smoke from burnt oil, not sure but I expect you have a cross over in the exhaust so you will get smoke out of both pipes...
Tg87 Member Since: 09 May 2019 Location: Suffolk Posts: 21 ![]() ![]() |
That would make sense. Fingers crossed 🤞. They can’t look at it till Tuesday, I love this car and really hope it isn’t completely shagged! |
fanders Member Since: 10 Jul 2013 Location: Hants, UK Posts: 318 ![]() ![]() ![]() |
When one turbo fails the loss of oil pressure due to the oil flow past the failed turbo seal can cause the ‘good’ turbo to also fail (according to my local indy (Keith Gott, Alton) - learned that when my TDV8 died, due to turbo failure. Plus the possibility of the engine hydro-locking on its oil into the induction system. So fingers crossed for yours, but be prepared for a range of outcomes.
Oh good, another turbo, that would be just my luck.
Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 696 ![]() ![]() ![]() |
The 4.4 TDV8 runs 'sequential' turbos where the second turbo doesn't come out to play until 2500-2700rpm are reached. In everyday driving it'll be unusual to use the second turbo. When I first had mine, I gave her a little 'welly' one day up to near 3000rpm & got the dreaded 'Restricted Performance'....cut a long story short, second turbo acutator was oil/gummed up through lack of use, all cleaned & running sweet. Just 'power up' to 2800rpm every now & again to get the second turbo running & she's sweet as a nut!
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4325 ![]() ![]() ![]() |
I had the secondary turbo on my 4.4 replaced as original one was weeping oil excessively
Hi Fox, I’m near needham market. I’ve just taken it to my local as they have been so good with me recently. Mansfield 4x4 couldn’t even look at it until the end of August. |
Mansfield 4x4 have looked after me & the FFRR since I bought her nearly 2 yrs ago.
I may give them a call today to get a price. It’s definitely turbo, I’ve removed the lower intercooler turbo hoses and plenty of oil there!
Turbo's are a little out of my depth if I'm honest.
