Home > Maintenance & Mods (L322) > Turbo Failure 3.6 TDV8
Tg87
Ok so since having the car (2009 3.6 TDV8) I’ve been changing the oil every 5,000, letting it cool for 30s before shutdown and generally trying to be nice to my dream car. I’ve removed EGR’s and had the BAS egr delete and maps applied. It’s now on 150,000, the gearbox was replaced at 110,000. One of the turbos had be done previously.
Driving today pulling out of a garage today I applied a fair amount of power and heard a clunk (which I thought at the time was the gearbox) then lost all power and had white/grey smoke spewing from the back end.
I pulled over and shut down. I tried to restart and it was lumpy as hell. Got recovered, read codes, nothing. No EML light, grey smoke from both sides, very lumpy idle.
Thoughts? Would you expect to see smoke from both sides of it was just one turbo? It’s sat at the garage awaiting someone to look at it but I’m trying to get a bit of a head start. Anything I can read on the IID tool to help diagnose?
Post #601596 23rd Jul 2021 2:46pm
When turbos fail it's usually white smoke from burnt oil, not sure but I expect you have a cross over in the exhaust so you will get smoke out of both pipes...
Sorry for your loss, fingers crossed it's just a pipe or similar... Pete
Post #601608 23rd Jul 2021 4:53pm
Tg87
That would make sense. Fingers crossed 🤞. They can’t look at it till Tuesday, I love this car and really hope it isn’t completely shagged!
Post #601643 23rd Jul 2021 8:11pm
fanders
United Kingdom 2009 Range Rover Autobiography 4.2 SC V8 Buckingham Blue
When one turbo fails the loss of oil pressure due to the oil flow past the failed turbo seal can cause the ‘good’ turbo to also fail (according to my local indy (Keith Gott, Alton) - learned that when my TDV8 died, due to turbo failure. Plus the possibility of the engine hydro-locking on its oil into the induction system. So fingers crossed for yours, but be prepared for a range of outcomes.
fanders ---------------------------------------
2009 4.2 SC Buckingham Blue
2021 Hilux 2.4
Post #601650 23rd Jul 2021 9:19pm
Tg87
Oh good, another turbo, that would be just my luck.
Is the 4.4 engine any more reliable or would I be opening the same can of worms?
Post #601671 24th Jul 2021 7:40am
Fox889
The 4.4 TDV8 runs 'sequential' turbos where the second turbo doesn't come out to play until 2500-2700rpm are reached. In everyday driving it'll be unusual to use the second turbo. When I first had mine, I gave her a little 'welly' one day up to near 3000rpm & got the dreaded 'Restricted Performance'....cut a long story short, second turbo acutator was oil/gummed up through lack of use, all cleaned & running sweet. Just 'power up' to 2800rpm every now & again to get the second turbo running & she's sweet as a nut!
As far as I know, this is the only turbo associated problem with the 4.4's.
As a matter of interest, whereabouts are you in God's very own county of Suffolk? I'm near BSE. 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
Alfa Romeo Giulietta
Austin A40 Farina MK2
1975 Morris Marina 1.8TC
1973 Honda CB250 K4
Post #601673 24th Jul 2021 7:51am
DrRob
I had the secondary turbo on my 4.4 replaced as original one was weeping oil excessively
No engine is infallible Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #601676 24th Jul 2021 8:15am
Tg87
Hi Fox, I’m near needham market. I’ve just taken it to my local as they have been so good with me recently. Mansfield 4x4 couldn’t even look at it until the end of August.
Post #601680 24th Jul 2021 9:18am
Fox889
Mansfield 4x4 have looked after me & the FFRR since I bought her nearly 2 yrs ago.
I had a few teething problems (oil cooler leak, turbo actuator) but apart from service items she’s been fine.
If you need any help I’m in Pakenham so not far away. 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
1973 Honda CB250 K4
Post #601701 24th Jul 2021 2:13pm
Tg87
I may give them a call today to get a price. It’s definitely turbo, I’ve removed the lower intercooler turbo hoses and plenty of oil there!
Is there anything else that I should check before “investing” in new turbos?
Post #601939 27th Jul 2021 7:58am
Fox889
Turbo's are a little out of my depth if I'm honest.
Ralph is head honcho at Mansfields, but if you ask for Frank [his son] he's very knowledgable & very easy to talk to/with.
Hope everything goes ok. 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
1973 Honda CB250 K4
Post #601941 27th Jul 2021 8:08am
