![]() | Home > Maintenance & Mods (L322) > Air con |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35508 ![]() ![]() |
air con looses gases after a while and i would certainly start with a regas and go from there. ... - .- -.
rangemad Member Since: 17 Apr 2017 Location: leicestershire Posts: 8 ![]() ![]() ![]() |
Thanks for reply
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1223 ![]() ![]() ![]() |
Definitely sounds like you have lost SOME gas. Before having it re-gassed, ask them to wave a detector 'sniffer' around the system to see if they can find a leak. Also, you can buy a detector for R134a for around £24 |
Main point is can you find a leak, if so then the system has to have the remaining gas recovered, system fixed, pressure tested and then re-gassed.
Thanks for all the advice 👍 |
i believe kwik fit and maybe others sell a regas with a 'if its not colder you get your money back' guarantee...worth exploring.. ... - .- -.
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7877 ![]() ![]() ![]() |
Or if it’s not that, have a read here....
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4325 ![]() ![]() ![]() |
Either a re gas needed but my money is on a new compressor. You have the classic symptoms of it |
