Home > Maintenance & Mods (L322) > Air con
rangemad
United Kingdom 2006 Range Rover Vogue Td6 Java Black
Air con
Noticed on my 2011 l322 tdv8
The air con can take 10/15 mins to get coldish !!!
Will it need a re gas
Seems strange as normally if a re gas needed it never gets cold. Any advice guys
Post #601006 18th Jul 2021 10:36am
air con looses gases after a while and i would certainly start with a regas and go from there. ... - .- -.
Post #601007 18th Jul 2021 10:38am
rangemad
Thanks for reply
I will get it done this week
Can any garage re gas
Or is it specialist job
Post #601008 18th Jul 2021 10:41am
Merchy
Definitely sounds like you have lost SOME gas. Before having it re-gassed, ask them to wave a detector 'sniffer' around the system to see if they can find a leak. Also, you can buy a detector for R134a for around £24
Post #601010 18th Jul 2021 10:48am
Merchy
Main point is can you find a leak, if so then the system has to have the remaining gas recovered, system fixed, pressure tested and then re-gassed.
If you use a detector £24, and find no leaks, then adding gas requires a tool with pressure gauge £20 and gas bottle £60 ( £10 refund on bottle ) Easy to do at home, loads of videos around showing how to do it.
Discounting the £44 for tools, I recently re-gassed four cars for a total of £100, thus £25 a car, happy days.
I do work on large A/C and Fridge plants as part of my job, but the videos should see you right as for testing / re-gassing. Hope this helps Thumbs Up
Post #601012 18th Jul 2021 10:55am
rangemad
Thanks for all the advice 👍
Post #601014 18th Jul 2021 11:08am
i believe kwik fit and maybe others sell a regas with a 'if its not colder you get your money back' guarantee...worth exploring.. ... - .- -.
Post #601015 18th Jul 2021 11:11am
mjdronfield
Or if it’s not that, have a read here....
https://www.fullfatrr.com/forum/topic43778...ed+air+con
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #601032 18th Jul 2021 1:04pm
DrRob
Either a re gas needed but my money is on a new compressor. You have the classic symptoms of it Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #601034 18th Jul 2021 1:14pm
