![]() | Home > In Car Electronics (L322) > MOST bus help |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8490 ![]() ![]() ![]() |
How wet is the inside, are the carpets sopping..??
LauraRR Member Since: 14 Sep 2020 Location: Ayrshire Posts: 4 ![]() ![]() ![]() |
Insides are fine, I sucked out my seats with a vax and carpets were protected with rubber mats.
Weird, there isn't very much in the console, think I'd start with leaving the engine running for an hour with the heater on full blast and the windows cracked open 1/2 inch, this should dry out what's left...
Locations of modules...
__________________________________________________ 2014 L405 Autobiography SDV8 4.4 Loire Blue Ebony interior 2012 L322 Autobiography 5.0 Supercharged Ipanema Sand Sold 2011 L322 Vogue SE 4.4 TDV8 Baltic Blue. Sold 2002 L322 Vogue 4.4 V8 Epson Green (Fatty Offroader) Sold -Click for Project Fatty off roader- |
More info...
The light signals are sent in one direction only and are formed in the following way: Electrical signals are converted into an electrical current The current then drives a light emitting diode (LED) in the FOT to produce a high intensity red light The LED transmits the light through a fibre optic cable A photo diode in the FOT at the opposite end of the fibre optic cable detects the light. The following components are connected to the MOST ring: Integrated Head Unit (IHU) Touch Screen Display (TSD) SDARS receiver (NAS and Canada only) Digital radio module (DAB and SDARS/HD (NAS and Canada only) TV tuner Audio amplifier Rear Seat Entertainment (RSE) module Telephone module Portable audio interface module CD autochanger. The IHU is the timing master for the MOST system. The IHU controls and manages the MOST ring and the system components. It is also responsible for the MOST security system. Each component in the MOST ring has a unique serial number. The component serial number is stored in a registry file in the instrument cluster. If any component serial number is not recognized, the entire audio system will not function. A replaced component requires its serial number to be programmed in the instrument cluster registry using Land Rover approved diagnostic equipment. If the instrument cluster is replaced, the complete system will not function until the instrument cluster is programmed with the component serial numbers using Land Rover approved diagnostic equipment. MOST Diagnostics A light box is used to diagnose the MOST system. The light box emits a visible, high intensity red light which can be connected into the ring at any point to test the ring integrity. The light box is used in conjunction with Land Rover approved diagnostic equipment. Disconnecting a MOST connector will reveal if the high intensity red light is visible. Do not view the red light directly. If a break occurs in the MOST ring fault codes are stored in the IHU which can be retrieved using Land Rover approved diagnostic equipment. CENTRAL JUNCTION BOX (CJB) GATEWAY FUNCTION The CJB (central junction box) incorporates a gateway function. The gateway function is the link between the vehicle bus systems and the audio system MOST ring. When the vehicle is unlocked, the CJB receives a system 'wake-up' message on the controller area network (CAN) bus. This message is then passed to the integrated head unit (IHU) which then 'wakes-up' the MOST ring components by energizing the infotainment relay. Pete __________________________________________________ 2014 L405 Autobiography SDV8 4.4 Loire Blue Ebony interior 2012 L322 Autobiography 5.0 Supercharged Ipanema Sand Sold 2011 L322 Vogue SE 4.4 TDV8 Baltic Blue. Sold 2002 L322 Vogue 4.4 V8 Epson Green (Fatty Offroader) Sold -Click for Project Fatty off roader- |
Hi
IIRC Portable audio interface is under the passenger seat, undo front and rear seat bolts and you can tip it back to get underneath, they are super heavy so best not to remove if you don't have to... |
Hi,
Glad you got it sorted, and remember, it's a Range Rover so anything is possible.... |
Shinner23 Member Since: 18 May 2020 Location: Virginia Posts: 6 ![]() ![]() ![]() |
I'm trying to track down my issue with blank head unit/orange light blinking. I know the Bluetooth is shot, but the read infrared light does not show up all the time (it occiasionaly will, but not always). I have a MOST Bypass for the BT on the way, but it seems the problem comes from the piece prior to the bluetooth Module, is that the Rear Seat Enertaiment? It's below the Bluetooth module? I have a 2011 RR HSE Lux. Thank you! |
Lauren_j23 Member Since: 22 Feb 2025 Location: Wales Posts: 2 ![]() ![]() ![]() |
Sorry to jump on this post, but could anyone help with a diagram of the most bus modules on the l405 2015 please |
You can download the workshop manual, which should show you, from the WIKI... link is at the top of this page under fullfatrr.com
