Home > In Car Electronics (L322) > MOST bus help |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8186 |
How wet is the inside, are the carpets sopping..??
11th Jul 2021 9:58pm |
LauraRR Member Since: 14 Sep 2020 Location: Ayrshire Posts: 4 |
Insides are fine, I sucked out my seats with a vax and carpets were protected with rubber mats.
11th Jul 2021 10:03pm |
Weird, there isn't very much in the console, think I'd start with leaving the engine running for an hour with the heater on full blast and the windows cracked open 1/2 inch, this should dry out what's left...
11th Jul 2021 10:18pm |
Locations of modules...
11th Jul 2021 10:23pm |
More info...
11th Jul 2021 10:34pm |
Hi
12th Jul 2021 11:14am |
IIRC Portable audio interface is under the passenger seat, undo front and rear seat bolts and you can tip it back to get underneath, they are super heavy so best not to remove if you don't have to... Pete
12th Jul 2021 12:19pm |
Hi,
15th Jul 2021 7:43pm |
Glad you got it sorted, and remember, it's a Range Rover so anything is possible.... Pete
15th Jul 2021 7:50pm |
Shinner23 Member Since: 18 May 2020 Location: Virginia Posts: 6 |
I'm trying to track down my issue with blank head unit/orange light blinking. I know the Bluetooth is shot, but the read infrared light does not show up all the time (it occiasionaly will, but not always). I have a MOST Bypass for the BT on the way, but it seems the problem comes from the piece prior to the bluetooth Module, is that the Rear Seat Enertaiment? It's below the Bluetooth module? I have a 2011 RR HSE Lux. Thank you! |
14th Jun 2022 5:16pm |
