Home > Maintenance & Mods (L322) > Second Battery Install Help
oggy
United Kingdom 2007 Range Rover Vogue SE 4.2 SC V8 Java Black
hi yes as long as the fuse is the same size as the fuse spur that they provide what size is that may be worth looking that up i suppose it is not that big new vehicle purchase
2007 supercharged 4.2 java black .sand leather vogue se trim
previous cars .
range rover classic 200 tdi
discovery 1 200 tdi
freelander 2 2008 hse
discovery 1 300 tdi
p38 4.0 ltr man r380 ex royal support vehicle on v5c
discovery td5 man off roader
Post #599829 6th Jul 2021 5:52pm
batfink
2004 Range Rover Vogue 4.4 V8 Adriatic Blue
Hi,
From memory I think the fuse they provided was 10A, but I’d have to check what the tow electrics are.
Post #599841 6th Jul 2021 6:51pm
oggy
yes i would if it is the same as all well and good just match what they provide with the kit new vehicle purchase
previous cars .
discovery 1 200 tdi
discovery 1 300 tdi
Post #599845 6th Jul 2021 7:03pm
The green / yellow wire is protected by fuse 2 and is rated at 5A so l don’t think you need to worry about an additional fuse.
Post #599862 6th Jul 2021 9:24pm
batfink
Brilliant, thanks 👍
Post #599863 6th Jul 2021 9:30pm
dazer2000
batfink wrote:
So an update on this. I've had Luxury Land Rover Upgrades contact me and they've said that I can splice into the Green cable that goes into the towing connector (white block near the fuse panel on the rear). So I'm assuming that's the same Green cable that was mentioned before.
He's going to send me another cable that will replace the fused cable so I don't need to go to the fuse panel.
For info his website has a few decent bits of kit and he's also said that he's going to be selling plug and play Bluetooth kits for these older RR soon.
Cheers for all the suggestions everyone Thumbs Up Thumbs Up
Did you get this sorted mate ? do you know what relay is used ? should say on it or pins numbers ? and what companents do they go to ? I have a 2002 RR like to do something like this.
Post #623228 10th Feb 2022 11:44pm
batfink
Hi,
I did get this all installed and sorted, I'll go and check what the relay is later, but you might get all the info from the pictures on their website:
https://www.luxurylandroverupgrades.com/pr...attery-kit
Cheers. Thumbs Up
Post #623240 11th Feb 2022 8:12am
dazer2000
Thanks mate, I cant see what pin numbers and where they go properly on the pictures, if I know the pin numbers ie 87, 37, 67 and what they are I should be able to se what one, I know its a 100amp just unsure on switching.
How has it been for you ?
Post #623264 11th Feb 2022 9:56am
