![]() | Home > Maintenance & Mods (L322) > Second Battery Install Help |
batfink Member Since: 20 Jun 2011 Location: Milton Keynes Posts: 193 ![]() ![]() |
Hi,
oggy Member Since: 09 Sep 2020 Location: padstow cornwall Posts: 395 ![]() ![]() ![]() |
yes i would if it is the same as all well and good just match what they provide with the kit new vehicle purchase
The green / yellow wire is protected by fuse 2 and is rated at 5A so l don’t think you need to worry about an additional fuse. |
Brilliant, thanks 👍 |
dazer2000 Member Since: 07 Feb 2022 Location: Portsmouth Posts: 2 ![]() ![]() |
Did you get this sorted mate ? do you know what relay is used ? should say on it or pins numbers ? and what companents do they go to ? I have a 2002 RR like to do something like this. |
Hi,
Thanks mate, I cant see what pin numbers and where they go properly on the pictures, if I know the pin numbers ie 87, 37, 67 and what they are I should be able to se what one, I know its a 100amp just unsure on switching.
