Home > Maintenance & Mods (L322) > Rear Brake Pipes for '02 - Look Right ? |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6408 |
Do these look right for the rear flexis ?
18th Jul 2013 5:24pm |
You need to make sure the banjo ends are the same as you have as there are two different types |
18th Jul 2013 8:28pm |
Thanks for the advice, I dive under Saturday morning .
18th Jul 2013 8:34pm |
Provided seller with VIN. Turns out these are not the right ones for my FFRR. They can get the right ones for £28 +VAT
20th Jul 2013 10:10am |
hoppy_70 Member Since: 04 Apr 2010 Location: Peoples Republic of Mancunia! Posts: 863 |
In had mine made by brakes international (front brembo). A braided hose was about £22 and much better design and life expectancy than the rubber hose. My Previous RR's!
20th Jul 2013 11:41am |
mat777 Member Since: 06 Apr 2015 Location: Nantwich/Liverpool Posts: 139 |
Bump - I want to replace mine with SS when I do the caliper swap, but nobody seems to make them? I had a goodridge set on my D2 and they were great, be a shame if they aren't made for FF's? NW060
19th Oct 2015 12:50pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8192 |
Front or back?? Pete
19th Oct 2015 3:36pm |
Both, when I get round to it (though front will be first) NW060
19th Oct 2015 5:22pm |
Find yourself a local hydraulics place. Agricultural, commercial, it really doesn't matter. If you show them a pattern they can usually make it in whatever material you choose. |
19th Oct 2015 7:43pm |
You won't notice any difference though, in the old days pre ABS they used to use very cheap rubber that was spongy and gave a poor pedal feel, the increased pressures now used in the braking systems meant they had to upgrade the material they are made of, stainless braided are now just a gimmick, no better than original, especially at the back where it is a two piece pipe with a metal section in the middle.. save your money and fit standard.... Pete
19th Oct 2015 8:54pm |
wats39 Member Since: 08 Jul 2012 Location: fife Posts: 77 |
For anyone interested, you can buy the parts and make up your own stainless steel braided hoses. Very easy to do. Used them on my previous Land Rover, my ffrr , kitcar, quad bike and never had a problem. You buy the hose per metre and whatever ends you need. Cost around £12 to £15 per corner when i did mine. I used Rally Design. Demon Tweeks also sell them. '04 td6 se
21st Oct 2015 9:24pm |
I'm not sure I'd personally trust anything I'd crimped together for use as a high pressure brake line!
28th Oct 2015 9:56pm |
You don't crimp the ends on, the lines come in different lengths with a standard threaded end, you then buy the particular end to suit our car that screws to the standard end, they work well but as I said earlier, not really worth it on the FF... Pete
28th Oct 2015 11:07pm |
FWIW I eventually capitulated and bought standards from LR Duckworths, to complement all my new pipework front and back .
29th Oct 2015 12:14am |
