Home > Maintenance & Mods (L322) > Rear Brake Pipes for '02 - Look Right ?
Do these look right for the rear flexis ?
http://www.ebay.co.uk/itm/RANGE-ROVER-L322...336941985c .
Post #199430 18th Jul 2013 6:24pm
You need to make sure the banjo ends are the same as you have as there are two different types
Post #199449 18th Jul 2013 9:28pm
Thanks for the advice, I dive under Saturday morning Wink .
Post #199451 18th Jul 2013 9:34pm
Provided seller with VIN. Turns out these are not the right ones for my FFRR. They can get the right ones for £28 +VAT
(Note: LR part now £66 +VAT Shocked ) .
Post #199690 20th Jul 2013 11:10am
hoppy_70
England 2018 Range Rover Autobiography 2.0 PHEV Loire Blue
In had mine made by brakes international (front brembo). A braided hose was about £22 and much better design and life expectancy than the rubber hose. My Previous RR's!
2018 P400e Autobiography
2008 TDV8 Vogue
2006 TD6 Vogue
2007 TDV8 Vogue
2007 RRS (I know, it doesn't count!)
2005 4.4 Vogue on LPG
2005 TD6 Vogue
2003 4.4 Vogue
2001 4.6 HSE
2000 2.5 DHSE
1999 4.6 HSE
1997 4.6 HSE on LPG
1995 2.5 DSE
1989 3.9 EFI classic
1988 3.5 EFI classic
Post #199715 20th Jul 2013 12:41pm
ebajema
Does anyone know where you can get sets of braided brakes hoses for the FFRR ?? I am considering replacing mine as our mechanics don't give a hoot about calipers "stretching" the hoses while waiting for parts (in my case sometimes weeks). I do go check regularly and put the calipers on something so the hoses don't get screwed but I'd feel better if they were replaced by braided hoses (used to do that on all my motorbikes as a standard rule, while replacing the brake fluid after I bought them). MY 2010 5.0 SC Galway green and sand interior!!
Post #199727 20th Jul 2013 1:43pm
mat777
United Kingdom 2005 Range Rover Vogue 4.4 V8 Giverny Green
Bump - I want to replace mine with SS when I do the caliper swap, but nobody seems to make them? I had a goodridge set on my D2 and they were great, be a shame if they aren't made for FF's? NW060
"Red Shed" - 1982 Series 3 88" County Station Wagon
"Spirit of Great Britain" - Rolls Royce Meteor V12 engine
ZG875 - Westland Sea King (cockpit section)
"Carly Rae Jeepsen" - 2006 Jeep Commander 5.7 Hemi
"Pride Of The Road" - 1/4-scale Marshall traction engine - sold
"Georgina" - 2000 Discovery 2 TD5 ES - sold
"Windsor" - 2005 Range Rover Vogue 4.4 - dead
Post #353073 19th Oct 2015 1:50pm
Front or back?? Pete
Post #353139 19th Oct 2015 4:36pm
mat777
Both, when I get round to it (though front will be first) NW060
Post #353161 19th Oct 2015 6:22pm
mzplcg
Find yourself a local hydraulics place. Agricultural, commercial, it really doesn't matter. If you show them a pattern they can usually make it in whatever material you choose.
Post #353185 19th Oct 2015 8:43pm
You won't notice any difference though, in the old days pre ABS they used to use very cheap rubber that was spongy and gave a poor pedal feel, the increased pressures now used in the braking systems meant they had to upgrade the material they are made of, stainless braided are now just a gimmick, no better than original, especially at the back where it is a two piece pipe with a metal section in the middle.. save your money and fit standard.... Pete
Post #353210 19th Oct 2015 9:54pm
wats39
Scotland 2004 Range Rover SE Td6 Alaska White
For anyone interested, you can buy the parts and make up your own stainless steel braided hoses. Very easy to do. Used them on my previous Land Rover, my ffrr , kitcar, quad bike and never had a problem. You buy the hose per metre and whatever ends you need. Cost around £12 to £15 per corner when i did mine. I used Rally Design. Demon Tweeks also sell them. '04 td6 se
'63 land rover s2 200tdi
'04 mk indy kitcar bike engine
Post #353543 21st Oct 2015 10:24pm
mat777
Shocked I'm not sure I'd personally trust anything I'd crimped together for use as a high pressure brake line!
If nothing is available off the shelf, I guess I'll have to go with some replacement genuine hoses. Interestingly, I have always found the brakes on mine to be quite spongy and lacking in feel, despite having been bled through with racing spec fluid - ergo I can only assume the the original rubber hoses have indeed gone soft NW060
Post #354547 28th Oct 2015 10:56pm
You don't crimp the ends on, the lines come in different lengths with a standard threaded end, you then buy the particular end to suit our car that screws to the standard end, they work well but as I said earlier, not really worth it on the FF... Thumbs Up Pete
Post #354556 29th Oct 2015 12:07am
FWIW I eventually capitulated and bought standards from LR Duckworths, to complement all my new pipework front and back Smile .
Post #354561 29th Oct 2015 1:14am
