![]() | Home > Maintenance & Mods (L322) > Rear Brake Pipes for '02 - Look Right ? |
Do these look right for the rear flexis ?
You need to make sure the banjo ends are the same as you have as there are two different types |
Thanks for the advice, I dive under Saturday morning |
Provided seller with VIN. Turns out these are not the right ones for my FFRR. They can get the right ones for £28 +VAT
hoppy_70 Member Since: 04 Apr 2010 Location: Peoples Republic of Mancunia! Posts: 869 ![]() ![]() ![]() |
In had mine made by brakes international (front brembo). A braided hose was about £22 and much better design and life expectancy than the rubber hose. My Previous RR's!
mat777 Member Since: 06 Apr 2015 Location: Nantwich/Liverpool Posts: 139 ![]() ![]() ![]() |
Bump - I want to replace mine with SS when I do the caliper swap, but nobody seems to make them? I had a goodridge set on my D2 and they were great, be a shame if they aren't made for FF's? NW060
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8379 ![]() ![]() ![]() |
Front or back?? Pete
Both, when I get round to it (though front will be first) NW060
Find yourself a local hydraulics place. Agricultural, commercial, it really doesn't matter. If you show them a pattern they can usually make it in whatever material you choose. |
You won't notice any difference though, in the old days pre ABS they used to use very cheap rubber that was spongy and gave a poor pedal feel, the increased pressures now used in the braking systems meant they had to upgrade the material they are made of, stainless braided are now just a gimmick, no better than original, especially at the back where it is a two piece pipe with a metal section in the middle.. save your money and fit standard.... Pete
wats39 Member Since: 08 Jul 2012 Location: fife Posts: 77 ![]() ![]() ![]() |
For anyone interested, you can buy the parts and make up your own stainless steel braided hoses. Very easy to do. Used them on my previous Land Rover, my ffrr , kitcar, quad bike and never had a problem. You buy the hose per metre and whatever ends you need. Cost around £12 to £15 per corner when i did mine. I used Rally Design. Demon Tweeks also sell them. '04 td6 se
You don't crimp the ends on, the lines come in different lengths with a standard threaded end, you then buy the particular end to suit our car that screws to the standard end, they work well but as I said earlier, not really worth it on the FF... |
FWIW I eventually capitulated and bought standards from LR Duckworths, to complement all my new pipework front and back |
