![]() | Home > In Car Electronics (L322) > Did all vogues in 2011 have dual screen or am I dumb? |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3802 ![]() ![]() ![]() |
I think it is truer to say most 2011 cars don’t have dual screens.
V8 Bob Member Since: 15 Mar 2018 Location: Cumbria Posts: 374 ![]() ![]() ![]() |
Vogue se at that age should have dual view. It was standard in the run out Westminster models and presumably the Autobiography models of that age. Can’t fine it mentioned in the Vogue spec on HJ. 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
Andygriff73 Member Since: 29 Jul 2018 Location: Ellesmere Port Posts: 68 ![]() ![]() ![]() |
I have a March 2011 Vogue and it does have but it was I believe a £625 option I am sure someone on the site has a 2011 brochure to confirm i viewed a 60 plate 2011 before buying this one and it didn’t have but I’m sure you could buy a replacement Dual view head unit second hand and someone on the forum must of done the upgrade. |
dennij Member Since: 23 Feb 2019 Location: Up North Posts: 450 ![]() ![]() ![]() |
My 61 plate Vogue SE doesn't have dual view and isn't listed on the build sheet so I would say it wasn't a standard fit at the time of my build 2011 TDV8 Vogue SE |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1399 ![]() ![]() ![]() |
The 2011 brochure shows dual view touchscreen as standard in AB, it was also in the WM, so not standard in Vogue or VSE. Only Range Rovers since 1988 |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7891 ![]() ![]() ![]() |
Standard on AB, £615 option on everything else....
Chieflongshin Member Since: 17 Mar 2021 Location: Uk Posts: 28 ![]() ![]() ![]() |
That’s interesting to know, if it helps mines a late 2011 I believe with rotary selector, looking at the above though I have the low spec
Mine is too. I have it though, as was chosen as an option . 2011 Range Rover Vogue SE 4.4 TDV8
RJH Member Since: 22 Mar 2015 Location: Coventy Posts: 398 ![]() ![]() ![]() |
My 61 plate Vogue has dual screen although reception is pretty poor & I’ve never watched anything on it!
Steve RR Member Since: 28 Jan 2013 Location: Ayrshire Posts: 16 ![]() ![]() ![]() |
So - on a 2011 VSE with standard screen, should it be a straight swap if I can get hold of a dual one? 2011 Disco 4
Siftah Member Since: 11 Jun 2018 Location: Barcelona Posts: 347 ![]() ![]() ![]() |
Believe it was an option, I have it on mine but it wasn't on all the cars I looked at.
F15KEY Member Since: 21 Jul 2021 Location: Taunton, Somerset Posts: 4 ![]() ![]() ![]() |
Hi there Siftah
It's actually a screenshot I found via Google, but yes, I have the Naviplus fitted which does give you CarPlay and Android Auto etc.
Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2944 ![]() ![]() ![]() |
I’ve got the dual screen on our 59 plate facelift Vogue SE. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
