Home > In Car Electronics (L322) > Did all vogues in 2011 have dual screen or am I dumb?
Chieflongshin
United Kingdom 2011 Range Rover Vogue 4.4 V8 Barolo Black
Morning all
I’m hoping I’m being dumb but it dawned on me I might not have the dual screen display if that’s a thing. I’ve been trying to work out how to use the tv from the passenger seat whilst in motion and as I’m normally in the drivers and have no passenger friends my curiosity of whether this works is currently unfulfilled.
I know how to operate the tv and get channels etc and then it mentions pressing the audio video key however I’m not sure if this works. My audio video button doesn’t have the little graphic with two screen above the words so it’s made me wonder and it doesn’t seem to follow the manual in terms of ease of use.
Can anyone clarify please if they all have dual screen in motion.
2011 tdv8 vogue
Post #591681 19th Apr 2021 8:04am
Baltic Blue
I think it is truer to say most 2011 cars don’t have dual screens.
Only very late 2011 and 2012 models are likely to have dual screens.
I looked at loads of 2011’s before buying mine, which is a single view Vogue SE from March 2011.
Post #591683 19th Apr 2021 8:41am
V8 Bob
United Kingdom 2012 Range Rover Westminster TDV8 Ipanema Sand
Vogue se at that age should have dual view. It was standard in the run out Westminster models and presumably the Autobiography models of that age. Can’t fine it mentioned in the Vogue spec on HJ. 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
200 TDi discovery bobtail gone
RR classic v8 bobtail gone
300 tdi Discovery 3 dr gone
Post #591686 19th Apr 2021 9:36am
Andygriff73
I have a March 2011 Vogue and it does have but it was I believe a £625 option I am sure someone on the site has a 2011 brochure to confirm i viewed a 60 plate 2011 before buying this one and it didn’t have but I’m sure you could buy a replacement Dual view head unit second hand and someone on the forum must of done the upgrade.
Post #591693 19th Apr 2021 9:59am
dennij
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Buckingham Blue
My 61 plate Vogue SE doesn't have dual view and isn't listed on the build sheet so I would say it wasn't a standard fit at the time of my build 2011 TDV8 Vogue SE
Post #591700 19th Apr 2021 10:29am
CS
The 2011 brochure shows dual view touchscreen as standard in AB, it was also in the WM, so not standard in Vogue or VSE. Only Range Rovers since 1988
Post #591706 19th Apr 2021 11:24am
mjdronfield
Standard on AB, £615 option on everything else....
 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #591710 19th Apr 2021 12:22pm
Chieflongshin
That’s interesting to know, if it helps mines a late 2011 I believe with rotary selector, looking at the above though I have the low spec
It was just boggling me doing as per the manual and not being convinced it was there
Post #591714 19th Apr 2021 1:07pm
mjdronfield
Mine is too. I have it though, as was chosen as an option . 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #591715 19th Apr 2021 1:09pm
RJH
England 2011 Range Rover Vogue TDV8 Santorini Black
My 61 plate Vogue has dual screen although reception is pretty poor & I’ve never watched anything on it!
I’d need to check the build sheet though to see if it was an upgrade.
Rob. 2011 (MY12) 4.4 TDV8 Vogue
2016 Golf GTI PP
Gone
Audi A4
VW Passat
VW Corrado G60
VW Golf GTI
BMW E30
Mini
Vauxhall Chvette
Post #591796 19th Apr 2021 9:55pm
Steve RR
Scotland 2011 Range Rover Vogue SE TDV8 Fuji White
So - on a 2011 VSE with standard screen, should it be a straight swap if I can get hold of a dual one? 2011 Disco 4
2011 TDV8 FFRR
4.6 P38 Autobiography x2
300Tdi county 110
Too many late Classic RR to count
Bowler Tomcat Smile
Post #602980 6th Aug 2021 10:03am
Siftah
Spain 2011 Range Rover Vogue TDV8 Stornoway Grey
Believe it was an option, I have it on mine but it wasn't on all the cars I looked at.
The way to know if you have it is the icon on the button should have two screens with a 1 and 2 on them.
To use it, you just press the button and the screen should change to the AV menu/TV depending on what was last selected.
Post #602983 6th Aug 2021 10:35am
F15KEY
England 2012 Range Rover Autobiography 4.4 V8 Santorini Black
Hi there Siftah
I notice that you have a 'car play' displayed on your screed!
I have a 2012 AB with Dual Screen and was wondering how you managed to get Car Play up?
Many thanks
Jimmer
Post #603314 9th Aug 2021 8:12pm
Siftah
It's actually a screenshot I found via Google, but yes, I have the Naviplus fitted which does give you CarPlay and Android Auto etc.
It works out around 1300 GBP and you have to fit it yourself, but there's more info here: https://www.fullfatrr.com/forum/topic56194.html
Expensive, lots of work, but IMHO very worth it!
Post #603335 10th Aug 2021 1:48am
Andy
I’ve got the dual screen on our 59 plate facelift Vogue SE. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #604467 22nd Aug 2021 5:26pm
