Home > Technical (L322) > Help!! Stuck in France with big boat on the Back! Horrible r |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35262 |
try and get a look underneath, it might be something as simple as the exhaust or exhaust covers rattling..
11th Apr 2021 2:49pm |
RanjRova Member Since: 16 Feb 2021 Location: Salisbury Posts: 16 |
Hi.. Thanks for reply..
11th Apr 2021 2:54pm |
Rosco Member Since: 20 Jan 2012 Location: Beyond the wall. Posts: 2575 |
Not good, sorry to say sounds like the TC has given up same happened with my TD6, identical symptoms.... hope you get sorted and its something easier |
11th Apr 2021 3:17pm |
Hi..
11th Apr 2021 3:22pm |
I took a video...
12th Apr 2021 5:39am |
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 |
That sounds very much like CV joint to me or possibly a UJ on propshaft, only from experience on other cars not RR. I'm sure others will advise shortly.
12th Apr 2021 6:08am |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3970 |
Between the front driveshaft and the rear of the gearbox there is a rubber doughnut joint. I'd be inclined to see if it is still intact and the bolts are tight and in place. |
12th Apr 2021 7:07am |
Hi ... Thanks for the replies..
12th Apr 2021 8:02am |
Treebor99 Member Since: 07 Feb 2021 Location: Rugby Posts: 34 |
I'll second the CV joint, sounds exactly like my old defender when it's CV broke. Could be a Universal Joint / doughnut in the prop shaft but they spin much faster and usually are felt as a vibration once your at up to speed.
12th Apr 2021 8:46am |
Thanks for all the messages guys...
12th Apr 2021 10:02am |
kevin-t Member Since: 24 Feb 2019 Location: Sheffield Posts: 39 |
Sorry.
12th Apr 2021 11:52am |
Discotigger Member Since: 12 Feb 2013 Location: Cumbria Posts: 804 |
It could possibly be the rear propshaft centre bearing has gone. The rubber surround on the bearing perishes / splits and you get a lot of noise and vibration when moving. You did mention that when you hit the propshaft it rang like a bell, so it could be that the rubber has totally gone, causing the clatter we could hear on the video. Towing a large boat may have put enough stress on the propshaft to cause the final failure of the bearing. |
12th Apr 2021 12:52pm |
verydisco Member Since: 10 Dec 2009 Location: UK/US Posts: 2952 |
May I suggest you join the french group and tell them where you are. there may be a local that could help, even if it is already at the garage.
12th Apr 2021 1:12pm |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3067 |
I can't add anything that the others haven't already.
12th Apr 2021 1:25pm |
