Home > Technical (L322) > Help me out with the suspension on my 'famous' 4.4TDV8 L322! |
Ffrr-lover Member Since: 04 May 2021 Location: Lincolnshire Posts: 640 |
With the car off (last used about 3 hours earlier), I tried bouncing the car using the lowered rear tail. The car suspension is stiff and I appeared to get less than an inch of travel with my slight and slender ( ) 16st frame pushing down.
16th May 2022 6:59pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7812 |
I know we don’t really know how it works… I’d hoped an expert might be on here….
16th May 2022 7:19pm |
MarianaWestminster Member Since: 14 Jun 2018 Location: UK Posts: 677 |
Thanks for the informative post FFRR lover.
16th May 2022 7:37pm |
Just been out the car with SDD and I can confirm with the engine running no current is supplied to the dampers until the vehicle begins moving.
16th May 2022 8:13pm |
Nice one. No point in me trying that comparison then.
16th May 2022 8:19pm |
Mjdronfield,
17th May 2022 6:21am |
Indeed. Would eliminate the “control system”.
17th May 2022 7:40am |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3249 |
Does it even respond to road undulations? IMO it’s just to control roll in corners and is not a ride comfort system. It can become a discomfort system when it fails though…. 2012 TDV8 Vogue (L322) |
17th May 2022 9:42am |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2491 |
Reducing roll in corners is a secondary use of the shocks, with smoothing bumps as suspension compresses and extends their primary task. Have you noticed how the vehicle doesn't bounce a couple of times after hitting a bump, unlike non-CVDs? The valves are operated to provide a controlled rise and fall of the body.
17th May 2022 10:29am |
Bilstein fronts are not as much of a bargain here than their rears. I can’t imagine there is an issue mixing brands front to back.
17th May 2022 10:37am |
LandyManSam Member Since: 10 Jul 2019 Location: Wild West Ireland Posts: 51 |
Hi all... apologies for the long delay. I don't get as much time for forum reading and posting as I'd like!
17th May 2022 10:38am |
Yeah….. seems to be looking like front struts for most parts. When mine hardened up, it was like flicking a switch… had new rears for MOT and that changed nothing.
17th May 2022 10:43am |
Dampers remove the oscillations at the resonance frequency of the suspension to avoid loss of tyre contact. If your suspension ‘bounces’ ( cvd or not) the shocks are worn and need replacing. 2012 TDV8 Vogue (L322) |
17th May 2022 10:50am |
I think Graeme means with 'normal' dampers, your suspension motion is a bit like the red curve, where it oscillates and overshoots the 'centre' position a couple of times before coming to a rest.
17th May 2022 10:57am |
