![]() | Home > Maintenance & Mods (L405) > Hatchbag bootliner and vents. |
Andy S Member Since: 16 Jun 2013 Location: Sevenoaks Posts: 1053 ![]() ![]() ![]() |
I have the hatchbag liner in my car, fitted the day I got it and never had a problem. |
Chasd Member Since: 10 Dec 2020 Location: North Devon Posts: 10 ![]() ![]() ![]() |
Thanks for the quick response but the vents must do something!
Not sure what the vents do to be honest, but the liner has some give so there is airflow. The liner has been in situ for 2 1/2 years without any issues. When I want access to the power outlet or the seat folding switches, I just peel the liner back to reveal them. That said, I rarely tip the seats or use the power outlet. If your use needs more frequent access then cutting small holes makes sense. |
TJH1985 Member Since: 11 Feb 2015 Location: Nottingham Posts: 664 ![]() ![]() ![]() |
The genuine LR boot liners have cut outs for them, it was one of the deciding factors in going genuine. I was a bit nervous that the quality wouldn't be as good but its been in over a year and still looks great |
adara Member Since: 09 Dec 2008 Location: Eastern Europe Posts: 800 ![]() ![]() ![]() |
You shouldn’t worry, there are more extraction vents just below the rear side windows. |
Alpinebullet Member Since: 23 May 2020 Location: Saddleworth Posts: 12 ![]() ![]() ![]() |
Bought and fitted the full Hatchbag liner as soon as I got my car last July. No issues whatsoever. Brilliant piece of kit. |
Thank you all for advice.
mlambton Member Since: 30 Sep 2021 Location: Devon Posts: 68 ![]() ![]() ![]() |
Id be interested to know how you are gettiong on with the Hatchbag. I bought something similar for my RRSport but the "adhesive" velcro strips applied to the boot sidewalls soon didnt stick any more and the sides no longer stayed in place.
Hi, in answer to your question - both fastenings used. The bootliner has not moved an iota!
I’ve had the current car for 3 years and the hatchbag was fitted the day I picked it up. Still in place, all Velcro still in place and the excess strip (the give you way more than you need) is still in my toolbox. Previous car was the same and I’m so pleased with the product I got one for my wife’s mini. |
Thanks Chasd and Andy S. Ill take your recommendation over the verrry expensive LR liner at about £350 2015 Range Rover L405 SDV8 AB Corris grey
Chalky Member Since: 10 Feb 2018 Location: Marshfield, Bath Posts: 926 ![]() ![]() |
I've now had Hatchbags on 5 cars and never had any problems with them.
diesel Dave Member Since: 14 Aug 2015 Location: Stockport Posts: 473 ![]() ![]() ![]() |
Hi, just for info. The vents in the back are the intake for the rear heater motor on the A/B, as you have 4 zone climate with separate motor, heater matrix and air conditioning for the rear passengers. |
ajac8 Member Since: 04 Oct 2011 Location: Shakespeares County Posts: 1664 ![]() ![]() ![]() |
We brought one from here: https://www.bootliners-uk.com/bl/land-rove...boot-liner
