Home > Maintenance & Mods (L405) > Hatchbag bootliner and vents.
Chasd
England 2016 Range Rover Autobiography SDV8 Carpathian Grey
I have just purchased a ‘Hatchbag’ fitted boot liner.
When in place the liner covers the vents on the near side of the boot.
I will cut small holes to access the deployable tow bar switches and the 12 volt plug but would rather not cut a substantial area over the vents.
Will having this vent covered cause any problems?
The Hatchbag is an excellent fit and protects the whole boot but will not be as practical if I remove a large piece.
Any advice/ suggestions gratefully received. 2016 SDV8 Autobiography 😀
Gone :Disco4 Graphite,-Disco Sport .-(BMW X3) .-Disco4 XS .-Freelander 2 HSE
(Hyundai Santa Fe) .-Disco TD5 .-Disco TDi .-Defender 110 TDi 200
Post #589084 26th Mar 2021 7:50pm
Andy S
United Kingdom 2015 Range Rover Vogue SE SDV8 Aintree Green
I have the hatchbag liner in my car, fitted the day I got it and never had a problem.
Post #589087 26th Mar 2021 7:55pm
Chasd
Thanks for the quick response but the vents must do something!
Although cutting out a large hole would defeat protection. 2016 SDV8 Autobiography 😀
Post #589088 26th Mar 2021 8:04pm
Andy S
Not sure what the vents do to be honest, but the liner has some give so there is airflow. The liner has been in situ for 2 1/2 years without any issues. When I want access to the power outlet or the seat folding switches, I just peel the liner back to reveal them. That said, I rarely tip the seats or use the power outlet. If your use needs more frequent access then cutting small holes makes sense.
Post #589103 26th Mar 2021 8:48pm
TJH1985
The genuine LR boot liners have cut outs for them, it was one of the deciding factors in going genuine. I was a bit nervous that the quality wouldn't be as good but its been in over a year and still looks great Thumbs Up
https://accessories.landrover.com/us/en/ra...ace-liner/ Sold - Bell a 2015 MY16 Loire Blue Autobiography 4.4 SDV8
Previously George a 2007 MY07 Java Black VSE 3.6 TDV8
Previously a 04 MY04 Defender 90 Sad
Post #589272 27th Mar 2021 7:52pm
adara
Romania 2019 Range Rover Vogue 2.0 PHEV Santorini Black
You shouldn’t worry, there are more extraction vents just below the rear side windows.
Post #589286 27th Mar 2021 8:54pm
Alpinebullet
United Kingdom 2013 Range Rover Vogue SDV8 Indus Silver
Bought and fitted the full Hatchbag liner as soon as I got my car last July. No issues whatsoever. Brilliant piece of kit. Thumbs Up
Post #589301 27th Mar 2021 10:13pm
Chasd
Thank you all for advice.
I have now fitted the Hatchbag cover and could not be more pleased.
Excellent fit and very well made.
I was obviously overthinking it, as stated there are vents at the bottom of the side windows. Thumbs Up 2016 SDV8 Autobiography 😀
Post #589308 27th Mar 2021 10:28pm
mlambton
United Kingdom 2015 Range Rover Autobiography SDV8 Corris Grey
Id be interested to know how you are gettiong on with the Hatchbag. I bought something similar for my RRSport but the "adhesive" velcro strips applied to the boot sidewalls soon didnt stick any more and the sides no longer stayed in place.
Does the Hatchbag hold itself in place with velcro sticky tape applied to the boot carpet sides or does it hook into the existing carpet? 2015 Range Rover L405 SDV8 AB Corris grey
2010 Range Rover TDV6 HSE Narra Bronze sold
2006 Discovery 3 SE green sold
Defender 90 td5 sold
Defender 90 soft top sold
Post #607965 2nd Oct 2021 6:27pm
Chasd
Hi, in answer to your question - both fastenings used. The bootliner has not moved an iota!
It is exactly as it was when first put in and it has had heavy use.
This is the fourth Hatchbag cover I have had in different vehicles, and the quality and fit just keeps on getting better. 2016 SDV8 Autobiography 😀
Post #607967 2nd Oct 2021 6:37pm
Andy S
I’ve had the current car for 3 years and the hatchbag was fitted the day I picked it up. Still in place, all Velcro still in place and the excess strip (the give you way more than you need) is still in my toolbox. Previous car was the same and I’m so pleased with the product I got one for my wife’s mini.
Post #607977 2nd Oct 2021 7:15pm
mlambton
Thanks Chasd and Andy S. Ill take your recommendation over the verrry expensive LR liner at about £350 2015 Range Rover L405 SDV8 AB Corris grey
Post #608011 3rd Oct 2021 9:56am
Chalky
I've now had Hatchbags on 5 cars and never had any problems with them.
You MUST however, clean the areas where the velcro sticky tabs are going on the car's bodywork. Use something like AutoGlym Tar Remover so that all the silicone used in the build on the bodywork is removed, otherwise as a poster has said, after a time, the velcro will come unstuck.
Hatchbag are the best, great quality and last for ever. Use it with a K9 dog box and a Boot Buddy clear shield above the rear seats and dog hairs and any smell are a thing of the past!! Thumbs Up Thumbs Up All LR cars from 1984
2021.5 Vogue SE D300 Carpathian Grey
2018 Vogue SE British Racing Green GONE
Post #608032 3rd Oct 2021 12:18pm
diesel Dave
England 2019 Range Rover Autobiography SDV8 Santorini Black
Hi, just for info. The vents in the back are the intake for the rear heater motor on the A/B, as you have 4 zone climate with separate motor, heater matrix and air conditioning for the rear passengers. Thumbs Up
Post #608072 3rd Oct 2021 4:40pm
ajac8
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
We brought one from here: https://www.bootliners-uk.com/bl/land-rove...boot-liner
It was for my Wife's F Type and fitted perfectly which was great given the indents, profiles and slopes in the boot of one of them.
Still good 18 months later.
I am tempted at this price but need to ask them if there is velcro where the load rails sit. 405 AB exec seats Baltic and Cirrus
93 RR Classic efi
Remember it's easier to get forgiveness than permission!
Gone in order:
4.4 TDV8 SE - gone to a good home
93 Classic hard dash Plymouth Blue
03 L322 Oslo Blue
2000 Disco TD5 ES Epsom Green
98 P38 Rioja Red
89 Classic Cairngorm Brown
Post #608100 3rd Oct 2021 6:17pm
