Home > Technical (L322) > Drive vibrations |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4310 |
How much !?!?! Feels like a rip off.
12th Mar 2021 9:53pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7847 |
Did the garage not diagnose it first?
12th Mar 2021 10:19pm |
Cappo Member Since: 19 Sep 2011 Location: Kent Posts: 537 |
There's another thread running currently re seized rear calipers; on both my L322s I have had this, if it happens you get a vibration through the car which can vary with speed (because the brakes get hotter when bound on at higher speed) and the seriousness of the seize. Sorted by a rebuild or new calipers. 5.0 S/C Autobiography - now gone to pastures new.... |
12th Mar 2021 11:40pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3979 |
^ +1 brakes sticking on for whatever reason. Had it myself, rear calliper seized. |
13th Mar 2021 10:40am |
Bl4ckD0g Member Since: 16 Feb 2020 Location: 127.0.0.1 Posts: 1322 |
+1 Had my callipers replaced as well. |
13th Mar 2021 10:49am |
vs322 Member Since: 08 Apr 2020 Location: Athens Posts: 589 |
Worth checking for engine misfires, too. |
13th Mar 2021 6:13pm |
coopss Member Since: 21 Apr 2018 Location: Hampshire Posts: 281 |
Check your wheels. Had mine checked by 3 garages who found nothing wrong, then one rebalanced the wheels and told me 2 were bent. Swapped and all sorted
13th Mar 2021 8:08pm |
Sam Member Since: 02 Jun 2017 Location: West Sussex Posts: 89 |
Under what conditions does the vibration occur, acceleration, braking steady cruise above a certain speed, engine load, over-run etc etc? |
14th Mar 2021 7:18pm |
