Home > Technical (L322) > Drive vibrations
udnyrangerover
United Kingdom 2002 Range Rover HSE 4.4 V8 Epsom Green
Drive vibrations
Crap......mega drive vibrations at most speed....from previous experience took it to be propshaft bearing....
Had the propshaft replaced at garage....£1k
AND crap vibrations still there....
Seriously Censored off
UPDATE
AFTER ORIGINAL ISSUES THE PROPSHAFT DID REDUCE SOME OF THE VIBRATIONS......
Now still there but appears to be from front ?? guess...
Had the wheels balanced, and 4 wheel alignment done, again changed but still there although different...
Whilst under car today oil servicing diffs etc found front shafts both have a fair bit of play on the inner joints.... more than I am used to feeling DO YOU FOLK THINK THIS MAY BE AN ISSUE
Post #587239 12th Mar 2021 9:33pm
DrRob
How much !?!?! Feels like a rip off.
Always start with wheel balancing as step 1 Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #587240 12th Mar 2021 9:53pm
mjdronfield
Did the garage not diagnose it first?
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #587241 12th Mar 2021 10:19pm
Cappo
2006 Range Rover Vogue 4.4 V8 Java Black
There's another thread running currently re seized rear calipers; on both my L322s I have had this, if it happens you get a vibration through the car which can vary with speed (because the brakes get hotter when bound on at higher speed) and the seriousness of the seize. Sorted by a rebuild or new calipers. 5.0 S/C Autobiography - now gone to pastures new....
Post #587246 12th Mar 2021 11:40pm
^ +1 brakes sticking on for whatever reason. Had it myself, rear calliper seized. Thumbs Up
Post #587279 13th Mar 2021 10:40am
Bl4ckD0g
Netherlands 2010 Range Rover Autobiography 5.0 SC V8 Santorini Black
+1 Had my callipers replaced as well.
Post #587280 13th Mar 2021 10:49am
vs322
Greece 2004 Range Rover HSE 4.4 V8 Java Black
Worth checking for engine misfires, too.
Post #587335 13th Mar 2021 6:13pm
coopss
Check your wheels. Had mine checked by 3 garages who found nothing wrong, then one rebalanced the wheels and told me 2 were bent. Swapped and all sorted
I had the vibrations at pretty much all speeds from about 35. The active suspension stiffens up the dampers as it thinks wheel tramp is going on - makes it unbearable 1995 4.6 v8, green/tan (long gone)
2005 4.8iS X5, blue/black
2011 4.4 tdv8, black/black (gone)
2003 3.0d X5, Oxford green/black/manual
2021 p575 SVR, BR green/vintage tan
Post #587364 13th Mar 2021 8:08pm
Sam
Re: Drive vibrations
Under what conditions does the vibration occur, acceleration, braking steady cruise above a certain speed, engine load, over-run etc etc?
Post #587467 14th Mar 2021 7:18pm
