![]() | Home > Technical (L322) > Drive vibrations |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4332 ![]() ![]() ![]() |
How much !?!?! Feels like a rip off.
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7910 ![]() ![]() ![]() |
Did the garage not diagnose it first?
Cappo Member Since: 19 Sep 2011 Location: Kent Posts: 537 ![]() ![]() |
There's another thread running currently re seized rear calipers; on both my L322s I have had this, if it happens you get a vibration through the car which can vary with speed (because the brakes get hotter when bound on at higher speed) and the seriousness of the seize. Sorted by a rebuild or new calipers. 5.0 S/C Autobiography - now gone to pastures new.... |
^ +1 brakes sticking on for whatever reason. Had it myself, rear calliper seized. |
Bl4ckD0g Member Since: 16 Feb 2020 Location: 127.0.0.1 Posts: 1322 ![]() ![]() ![]() |
+1 Had my callipers replaced as well. |
vs322 Member Since: 08 Apr 2020 Location: Athens Posts: 596 ![]() ![]() ![]() |
Worth checking for engine misfires, too. |
coopss Member Since: 21 Apr 2018 Location: Hampshire Posts: 281 ![]() |
Check your wheels. Had mine checked by 3 garages who found nothing wrong, then one rebalanced the wheels and told me 2 were bent. Swapped and all sorted
Sam Member Since: 02 Jun 2017 Location: West Sussex Posts: 89 ![]() ![]() |
Under what conditions does the vibration occur, acceleration, braking steady cruise above a certain speed, engine load, over-run etc etc? |
